Question about Car Audio & Video
My pioneer gm-h100 amp does not have a remote wire hook up on the amp
  • Anonymous Sep 07, 2008
    no remote wire chanel
There should be a wire harness that clips into the side of the amp if you dont have the clip u can just use some end conecters and hook it up to the two pins that are on the side and hook that to the remote wire.
Posted on Aug 20, 2009
PIONEER GM-D8500M will it still work with no remote ???
Use the system control terminal. It is basically the same as a remote turn on.
Jul 02, 2012 | Pioneer Gm-d8500m Car Amp
Show me a picture how to hook up this pioneer gm-h100 amplifier
What do the red and black wire go to coming out of the harness?
Jan 04, 2012 | Ford F-150 Cars & Trucks
Can not find where to hook the rem wire on my pioneer gm-h100
This remote wire requires a switched 12 volt .This can be connected at fuse panel and or to radios remote out or power antenna wire.
Sep 22, 2011 | Car Audio & Video
Red light showing up on amp ( pioneer 800 watt GM 7200 amp )
it could be the amp it could be the way you've installed and if you have a sub in an enclosure the wires could be touching the postive and negetive speaker wires what ever the problem is the amp is in protection mode i hope this helps hope its not the amp i hope its just the wiring
Jun 05, 2009 | Pioneer GM-7200M Car Audio Amplifier
No power with amp
make sure the remote wire has juice when the head unit is on then check ground
Nov 25, 2008 | Pioneer GM-7100M Car Audio Amplifier
I have a Pioneer GM-H100 amp and I can not figure out the whole 3 prong thing is there a special wiring for it i have seen mixed comments of this same problem on different website can you please help me...
I have a gm-h100 amp. The three prong plug is for a remote turn on. Mine has two wires one of which goes to the radio where it gets a power on sigonal (12 volts when the radio is on). the other wire goes to the an accesory fuse where it gets 12 volts when the key is turned on. the amp needs both of these before it will run
Jul 23, 2008 | Car Audio & Video
Witch is better
hi there. ill start with the wiring. you should have a blue remote lead going to the back of your head unit, the power cable running straight from the amp to the battry, the earth should be earthed in a fairly decent place, any metal inside the car realy, and then your wires pos and neg from the amp to the subs. the reason why the kenwood might not have much base on it is to my knowledge, there should be a switch somewhere on the amp that will increase or decrease the power input for the speakers, if this is set very low then hense why theres not much base comming from them. if the amp is on and its giving something to the subs it probably isnt the wiring. try checking the amp for the switch first, if you cant find it try the pioneer amp and see if theres any diference.
dont hesitate to contact me if you get stuck
cheers, adam
Oct 31, 2007 | Pioneer GM-7200M Car Audio Amplifier
Pioneer GM-7300M 800 Watt amp will not power on
This may have a different type of triggered turn on wire. On some of the older Pioneer amps (and maybe some new ones) the trigger wire would SUPPLY B+ TO THE RADIO and when the radio was switched on the amp would sense a current draw on that wire and would then switch on. Unlike most common amps which sense the presence of B+ on the trigger wire supplied by the radio and then turn on. Look in your owners manual to see kind of turn on system you have. If you don't have an owners manual then perhaps you can download one from Pioneer support. good luck
Aug 23, 2007 | Pioneer GM-7200M Car Audio Amplifier
Car Audio & Video Logo
731 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
