Samsung TV Model TC9875T The set is dead. No relay click.
    New Friend:
  • 50 Answers
Check the fuse, the regulator IC, diodes and open resistor in the power supply section...
Posted on Aug 11, 2008
SOURCE:
I've replaced every board on the samsung plasma and still clicks
What do you mean by clicks? Plasma televisions are hot cathode ray, there is thermal expansion that takes place due to heat.
Nov 04, 2016 | Samsung Televison & Video
Samsung 50" plasma HPS5033X/XAA shut off and will
HGi:
This model is nortorious for Y-sustain board failure, replace the Y-sustain board and you should be good to go. The Y-sustain board is the one while standing with back off the set is the board on the left side of the television.
Jul 05, 2011 | Samsung HP-T5044 50 in. Plasma TV
Samsung PS42B430 42" Plasma tv. LED flashes and
The tv power supply board have more dead components parts,u just don't have the skills an the know how to trouble shoot find out more dead components parts that all.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 11, 2011 | Samsung PS42B430 42 in. Plasma TV
My tv goes click click click and keeps clicking when i turn it on. I have no picture or sound
In most cases it is the capacitors in he power supply section that have gone out.
Common symtoms are
-shuts down
-takes a long time to come on
-relay clicks
-dead set
You can get capacitors online or you can get a complete kit with instructions and support from www.TvRepairKits.com . Its a failry easy DIY fix.
Dec 13, 2010 | Samsung LN46A650 46 in. LCD HDTV
My samsung tv model LNT4061F keeps turning on and off continuely and when it does come on it has a lot of different color lines in it with no picture. To describe it better it looks like wall paper. I...
Common symtoms are
-shuts down
-relay clicks
-dead set
Dec 12, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung tv model no LE40R74BDXIXEU TV IS USUALLY
First the main bd controls the "Turn on" sequences". When you press the Power on button the Main bd sends a "Turn on" signal to the Power supply. The clicking you hear is the Power on relay ativating. If the tv does not turn on and the relay keeps clicking then you might have a bad Main bd or there is s shorted board somewhere else in the set. The Power supply can also be bad. Have a trained Samsung tech troubleshoot the set.
Jul 12, 2009 | Samsung Televison & Video
TV will not turn on
Hi, make & model ? clicking is tv`s relay turning set on but set shuts down because power supply has a dead short in it, you will need a tv tech to fix this one, gl,
Jun 08, 2009 | Televison & Video
Samsung TV Won't Turn Off
if this set has a power relay the contacts in the relay are welded closed; unplug set for 10 seconds and plug back in; it will probably come streight on if relay is stuck. replacing relay will fix if this is the case
Apr 29, 2008 | Samsung TX-R2435 TV
Samsung txe2745 just quit working -- has an internal "clicking" like a relay trying to close
First of all greetings from Belize mike your set is an old set but you can still get some life out of it please be inform that going into a tv could cause you self injury if you are not qualified to handle an electronics set.the problem with your set is in the power supply there is a 10mf cap situated in the power supply just close a transistor replace it along with power requlator and associated diodes.that will solve your problem.but make checks in the power supply.if you cannot do it yourself take the set to tech.good luck.
Nov 21, 2006 | Samsung TXE2745 TV
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
