Question about Kenmore Dishwashers
It does not seem that my dishwasher arms are putting out enough water pressure. the top arm does not spin at all the water just spits out of them. my water pressure has not changed in the house and it does this with nothing loaded in it.
    Genius:
  • 1,122 Answers
Sounds like the water pump is clogged,remove hose and **** out with shop vac,thanks-mike
Posted on Aug 11, 2008
The spray arms aren't spinning, any ideas?
The main water pump sounds to be defective, not supplying enough water pressure to turn the spraybars.
Nov 05, 2015 | LG Dishwashers
My top shelve sprayer arm does not spin
its just clipped over the cap remove and clean also check the seal is not damages on the pipe that goes into case.
Jun 18, 2017 | KitchenAid 24 in. KUDI02IRBS Stainless...
I have to initate the spinning of the sprayer arm.
uasally it isnt the spinning of the spary arm that does the fill it is controlled or a timed fill then the motor comes on if there isnt enough water in the unit it will not have enough pressure really need more info though
Jun 02, 2010 | Dishwashers
Top wash arm doesn't spin.
This is usually due to restrictions from debris in the sump area of the pump, it will not allow enough pressure from the pump to spin the upper arms. I have put together some instructions on cleaning this on your model, follow the link below and let me know if it was helpful.
Whirlpool pump cleaning
May 28, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Jan 17, 2009 | Dishwashers
Top arm not spinning
only the top rack isnt getting clean?
there is a little plastic circle in the middle of the bottom of the upper spray arm. turn it counter clock wise to pull the upper spray arm from the upper rack. make sure that isnt clogged and the spray holes are not clogged. otherwise....
the piece that the bottem spray arm plugs into and runs along the back wall of the tank to the top is called a feed tube. pull the bottom spray arm out. now you can see the part of the feed tube that feeds the upper spray arm water. does it pop out freely and easily? if so then you need a new feed tube, if not then its most likely your not achieving the right water level or your impeller connected to your circulation pump(motor) is clogged not supplying enough water pressure to travel up the feed tube to spin the upper spray arm.
Jul 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Frigidaire 24" fdb641rj dishwasher
the check-ball runs the top spray arm both arms don't run at the same time and that's the correct fill for this model whats your problem
Feb 07, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Spinning arms stationary
problem is usually debris in the end angled jet of the spray arm which is used to turn the arms. take them outy and patiently clean. very common problem
Apr 24, 2007 | Neff 24 in. S4443 Built-in Dishwasher
Dishwashers Logo
79 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
