I'm trying to connect a netgear router wgr614 to xp have modem hooked up with usb port not ethernet port, i've tried to use both cords (ethernet cables) have two ethernet cards in computer but could not get on internet so went with usb hookup, so do i go with only one cord or two cords
    Scholar:
  • 65 Answers
I would just stay with the usb if it works. unless your wanting to use the net card instead?
Posted on Aug 11, 2008
Cannot restore factory settings
You need to consult a qualified Technician.
Apr 17, 2017 | NetGear WGR614 Router
Netgear WGR614 router with USB Cable Modem
When working with routers, CAT-5 cables are the more usual cable used. Your modem's Ethernet Port --- connect it via cable to the router's WAN input. Connect one of the router's LAN outputs to your computer's LAN input with another CAT-5 cable. Go through the appropriate Router Setup by putting http://192.168.1.1 into your Internet Explorer, with ' admin ' for User Name, and no password (just press Enter in Password frame). Once you are in to the router setup, you can select your Network Name (SSID) and then implement whatever Security you might want to use. You should be up and running by now, nhave lots of fun!
Dec 18, 2009 | NetGear WGR614 Wireless Router
How to connect Netgear to Time Warner internet modem? I have Netgear installed on my computer, and I have the internet modem plugged in to my computer.
Just disconnect the ethernet cable from the computer and put it into the slot called internet on the router then run ehernet cable from port 1 to computer.
Dec 05, 2009 | NetGear WGR614 Router
I have a NetGear WGR614 Wireless Router and internet through Mediacom with a Motorola SB5100 SURFboard cable modem. I have gone thru the setup process three times now, and the internet has hooked up twice...
Follow the below steps to reconfigure the router:
Connections:
1. Connect a Ethernet cable from the modem to the WAN port of the router(isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that THERE IS NO DIRECT CONNECTION BETWEEN THE MODEM AND THE COMPUTERS (either using Ethernet cable or USB cable).
3. Power off the modem and the router after making the connections.
4. Power on the modem and wait for the lights, then power on the router.
RECONFIGURE:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the username and password is case sensitive).
4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section.
5. Click Apply.
6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Oct 08, 2009 | NetGear WGR614 Wireless Router
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
NetGear Wireless Router and connecting using a USB Modem
I think you're saying that you want to set up a Netgear from a wirless port. Is that the ONLY computer you have?
It's not IMPOSSIBLE, but it is improbable. By default, the Netgear has the address 192.168.1.1. If nothing else on your network has that address, it might be possible to plug in the Netgear, set the IP address of your computer to 192.168.1.2-254, and link to 192.168.1.1.
I didn't say easy, just possible. Easy would be to use a computer with a wired ethernet port or grab a friend with a laptop with a wired port. It's a 15-minute job.
Carl
Apr 10, 2009 | NetGear WGR614 Wireless Router
Connecting router to satelite modem
As long as your sat modem has an ethernet port you could hook it up the same way...Hope this helps!
--Joshua79
Apr 05, 2009 | NetGear WGR614 Wireless Router
Issue with router and ethernet cables
I imagine you reset/unplugged all of your routers, switches, and computers, starting with your modem, then router, and then each system?
There is a setup disk that need to be used to program your router with the ISP settings, passwords, and protocols for port forwarding, etc. I imagine you tried that.
Did you try all of your cables to make sure they weren't defective?
If you tried these,and the problem persists, the issue is a defective router. By default, the unit should transmit a wireless signal, and be ready to act as a routing switch for your other systems.
Mar 26, 2009 | NetGear WGR614 Wireless Router
How do you hook up your netgear wireless router to your clear wire modem?
Hi Leon,
have alook at Clearwire's webpage (here), where they describe different setups for your router.
I personally would always prefer to connect the modem to the router via a cable. The cable you will need is an Ethernet (CAT5) cable and the connectors at the end look like this (compared to a phone cable:
You will connect the output of your modem with the WAN port of your router. This port is usually separated form the 4 other LAN ports, which connect to your computers, printers, etc.
(You didn't specify which router model you have, so I can't give you more details, but it should be very obvious, when you look at the back of your router.)
For the initial setup of your router, you should use a second Ethernet cable connected to one of the LAN ports of the router and to the Ethernet port of your computer.
If you need help with the wireless setup of your router, you have to look either in your manual of give me the details of your router (like the model and version, i.e. Netgear WGR614) and I'm happy to assist you.
Feb 25, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
