Question about Acer ScanPrisa 640P Flatbed Scanner
Drver downloaded It works slowly, in order to get a page I need at least 10 minutes. And also there's only one task at once to make it work, when I got the scanner I was able to program various tasks at once but I was used to working with win 98 edition.could you an help me please?
Corodie65
Posted on Aug 11, 2008
How do I access the battery
The Bladefish doesn't have just one battery. There are several. I can only speak for the bladefish 3000. It has 5 batteries. They are 3.7 volt LiMg high drain batteries that have and expected life of 2 to 3 years whether you use the bladefish or not. You should not attempt replacement of the batteries if you do not have some experience in electronics repair. The batteries are bonded together in one group of three and one group of two. There are about 10 wires that are soldered directly to the batteries so experience with soldering is mandatory. That being said, they are accessed by removing the screws around the front cover and removing the foam pieces under the cover. Then you have to remove the nut on the front of the propeller blade and remove the drive belt and the small drive gear from the motor shaft. once that has been done you can slide a putty knife under the edge of the clear cover and slowly pry it open slowly as you work your way around the unit. I've read that this is almost an impossible task but I did all of the above in about 30 minutes. The real difficult task is to do the physical replacement of the batteries. This requires real skill with a soldering iron and attention to detail. You cannot risk making a mistake in replacement of the wires. Battery polarity is critical. If you get on battery wrong you risk serious damage to the electronics of the Bladefish. When done with the battery replacement you need to be sure to put silicone grease on all of the seals then slowly press it back together and re install the hardware. Any Questions
Aug 25, 2014 | Bladefish 5000 DPV Sea Scooter
TAKES 45 MINUTES TO COME ON
Evidently there is an internal power supply problem.
Nov 12, 2013 | Televison & Video
I have a brand new MSI wind u135 nbook which runs windows 7 starter, and for some reason the web pages either load very slowly or not at all. This goes for both IE and Firefox. The connection is good and...
This is probably a RAM issue concerning windows 7 program usage open your task manager (ctrl alt delete and click task manager) and see how much RAM both the internet and other programs you have up take.
Mar 01, 2011 | MSI Wind U135-415US 10-Inch Netbook White...
Sir, i have compaq presario V6604AU model.This model work fine with vista OS but when am install XP i face sound & disply driver problem. when am try trying to install drver it show the messag(...
<span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-AU; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP Windows version of the drivers you require and install them. Click on this link to download the drivers: -<br style="mso-special-character: line-break" /></span><br /> <span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-AU; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"></span> <br /> <span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-AU; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-AU; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href="http://www.compaq.com/country/cpq_support.html">www.compaq.com/country/cpq_support.html</a></span></span><br /> <span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-AU; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-AU; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"></span> <br /> <br style="mso-special-character: line-break" /><br /></span>
Aug 30, 2010 | Computers & Internet
E-mail does not work with my 9530
Your phone will have to have upgraded firmware to make the switch.
Instructions for upgrading a blackberry handset 1. Goto http://www.blackberry.com/support/index.shtml
2. Under the heading "downloads" select "service packs"
3. Select "Blackberry Desktop Software 4.1" in the pulldown menu
4. Choose service pack 1 (English) or service pack 1 (multilingual) if required
5. Now download this to your pc and run the installation
Now you need to download the firmware upgrade to support your handset.
Select your network from the list below to be taken to their firmware page then choose the newest firmware version for your model :
Nextel : Downloads Page Verizon Broadband Access 4.0.2 : Downloads Page Telus : Downloads Page Orange : Downloads Page Bell Mobility : Downloads Page Vodafone UK : Downloads Page Sprint : Downloads Page Vodafone Ireland : Downloads Page Verizon : Downloads Page Vodafone Australia & Fiji : Downloads Page Cingular / AT&T : Downloads Page Vodafone New Zealand : Downloads Page T-Mobile : Downloads Page Cable and Wireless : Downloads Page Rogers : Downloads Page Dobson Cellular / Cellular One : Downloads Page Telstra Australia : Downloads Page SunCom Wireless : Downloads Page Hong Kong CSL : Downloads Page Optus Mobile Pty Limited : Downloads Page Bharti Tele-Ventures Limited : Downloads Page KPN Netherlands : Downloads Page O2 Ireland : Downloads Page O2 Europe : Downloads Page
6. Start the Blacberry desktop manager and plug in your blackberry.
7. Desktop manager will prompt you that there is a new version
8. Proceed with the install
9. Make sure you select the backup option
10. Once your upgrade is complete, your Blackberry will take around 5 minutes to reboot.
11. Now you can proceed to unlock your phone
May 15, 2009 | RIM BlackBerry Storm 9530 Smartphone
LG WD-1021-WF Front Loader Washing Mashing
Not a hard task if you coat rims with liquid detergent before trying to install new seal.
Using thumb go slowly around rim working seal all the way back.
Replacing main spring can be done by working bottom to top and then hold left side of spring in place while you pull right side in with long nose pliers.A couple of minutes difficult work and your 90% done.
Care is required so as not to puncture seal,
Main point is to ensure seal is fully seated before applying spring.
Having machine laid on its back makes the job so much easier.
This job took an hour and 30 minutes, the hour spent checking the internet first.
Good luck
Kevin
Jun 20, 2008 | LG WD-1280FHD Front Load Washer
Virtual memory
dear barbwire
your hard drive nearlly full in which your os is installed.so pls increase your winxp drive capacity or remove program and data which are not importent or send them to other drive .then remove temp files. perform disk cleanup.and run chkdsk utility in cmd. your problem is solved.
bye.
kishor khatri
Mar 18, 2008 | Computers & Internet
Acer ScanPrisa 640P Flatbed Scanner Logo
27 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
