Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Panasonic tv doesn't turn on
Pt-53wx54 53 inch projection tv. i went to turn it on and it made the sound like it was turning on after a few seconds it made a sound like it was shuting off, then the light by the power button just falshes 3 times then pause then over again
  • 5 more comments
  • jmmudge Aug 11, 2008
    if it was a fuse would it keep doing the same thing. sound like it is starting up then stop. and the red light flash. it is probably 2 years old
    do i have to take off the back panel to get to the fuse
  • jmmudge Aug 13, 2008
    fuse i found inside was good it was by the power cord
    anyone else have any ideas
    i can unplug it and plug it back in and it does the same thing the blue and red bulbs light up not the green then shuts off
    i just saw the comment about the ICs, i don't know much about the electronics in the tv, is this going to be like a plug and play repair or is there some soldering that needs to be done, could i ruin the tv more, thanks for the help
    what is the backlight , is that the light that didn't light up if so, what about the convergence chips
    Master:
    Sergeant:
  • 462 Answers
Dont worry... to not to ruin ur tv... and also to get it repaired u can take it to a nearest service centre because i am afraid new to soldering n circuits... so to be on the safer side this cud be the best thing to do...
Posted on Aug 13, 2008
    Novelist:
  • 106 Answers
Just to make sure, try to plug-in the power cord of your tv directly from the walljack or to any ather power outlet. It might be an issue with the power shortage, or the outlet that you are using to plug-in the power cable/cord doesnt have enough electricity or defective.
thank you so muc.
adonscott
    Sergeant:
    Champion:
  • 248 Answers
Probably the backlight is out. However, I do not recommend anyone unfamiliar with electronics messing around in a television, projection type or otherwise. Capacitors inside a TV can store 10's of thousands of volts, loooooong after the set is unplugged. It can be VERY dangerous.
  • Panasonic Master
  • 8,617 Answers
Thats the error code for the convergence ICs needing replacement. You can get both replacement ICs STK392-110 and the six 2.2 ohm 2 watt resistors for R7011, R7012, R7013, R7014, R7015 and R7016. There is akit which includes everything for under 47.00 to repair your kit it is at the following link called panasonic convergence repair kit #1 which has the resistors and ICs and comes with instalation instructions. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Aug 11, 2008
  • Sonny Berry
    Sonny Berry Aug 13, 2008
    Ther is definately soldering involved. I would suggest a tech do it if youre not comfortable soldering, But 3 blinks means the convergence ICs have shorted definately
    Master:
  • 848 Answers
Just check the fuse it might have been blown.....also how old is you tv ?
My name is Callie and my panasonic PT-60LCX64 projector tv wont turn on. I can hear it running and hear the fan, and read about a switch that needs to be pressed in but i cant find the switch.
PT-60LCX64 - Panasonic
shop.panasonic.com > Get Support
Panasonic60" Diagonal LCD Projection HDTV. ... Details http://shop.panasonic.com/support-only/PT-60LCX64.html ... Will the Touch Pen (TY-TP10U) work with my TV?
Panasonic TV Not Turning On? (PT-60LCX64)? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: https://tr.im/EBjDN ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Panasonic PT60LCX64 Lamp with Housing TY-LA1000
www.amazon.com > ... > Projector Accessories > Lamps
Amazon.com, Inc.
Rating: 3.8 - ‎30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
Panasonic LCD Projection 1 Orange Amber Blink PT 43 50 ...
? 5:48
https://www.youtube.com/watch?v=Z9tLqxpD1qU
Apr 18, 2013 - Uploaded by norcal715
Dec 26, 2015 | Panasonic Televison & Video
Why will my Panasonic 52 inch rear projection will not turn on?
I had a 50 inch projection tv and when the bulb would go out there was always a popping sound. I went on ebay and found a new bulb at half the price the tv maker wanted. I would replace the bulb. If that is not the problem then you will just have a spare that will be needed at some point.
Apr 26, 2014 | Panasonic PT-52LCX66 Projection Television
Turned on tv with remote (this turns on cable box and tv). TV came on for a few seconds and then went off, no picture, no sound. Remote would still change channels on cable box, so it is obviously the...
Most of these have a shutdown feature built in and if you unplug the set, plug it back in and turn it on manually look carefully at the power light on the front when you turn the set OFF.
It should blink a specific sequence: 3 blinks, a pause and 3 blinks etc.
3,3 and 5,5 are the most common and mean different things are wrong.
Let me know if you are able to see the error code.
SD TECH
May 11, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-51HX41 51 inch
If the power led blinks its an error code such as 3 blinks means convergence failure which is the most common error for your model.Let me know the error code and I will assist you with what you need to do.
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Can you post how many blinks the power indicator is blinking as that is an error code such as 3 blinks means Convergence circuits.
Mar 02, 2009 | Panasonic PT-51HX41 51" Rear Projection...
My Panasonic PT-53WX52 rear proj. TV won't turn on?????????
from what I have found out their is a problem with the power unit inside the television. Could be a convergence chip that shorted out
Nov 20, 2008 | Panasonic PT-53WX52 53" Rear Projection...
Panasonic Rear Projection TV PT-47WXC43
I have a Panasonic PT-47WXC43 47 in Rear Projection. It went off, on picture, no sound.
Jul 13, 2008 | Panasonic PT-47WXC43 47" Rear Projection...
47 inch Pabasonic Project T.V.
This could be part of the text mode, which has to do with the caption. Check and see if it's turned on.
Aug 12, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
76 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
