Question about Whirlpool Kitchen Ranges
I have a whirlpool range,the model number is SF306PEGQ.The problem i am having is with the oven.The glow plug works,but the gas takes a long time to ignite and the flames come on and when they do are very small.When i tap on a square box attached to the bottom of the oven attached to the flame ports it works fine.I think the box is a valve operated by heat.Thank-You for your support.
SOURCE:
Kgt1962
  • 59 Answers
SOURCE: viking range - gas flame on one burner does not change
It sounds like the repair man was correct. The only variable is the valve, if the rest of the burners are fine then it will be the valve
Posted on Mar 09, 2009
  • 4 Answers
SOURCE: oven wont light
Have qualified person check safety valve and replace if necessary. DON'T SCREW AROUND WITH GAS IF YOU DON'T KNOW WHAT YOU ARE DOING OR
BAANG, YOUR DEAD!!!!!!!!!!!!!!
Posted on Mar 25, 2009
protek480
  • 1730 Answers
SOURCE: Gas Oven - no flame at Bake Baffle - Glow Bar glows fine
If the glow bar is working (glowing) it is the gas valve. BUT, the glow bar can also actually glow and still not be working 100% and letting enough current through to the valve. You could swap an identical valve out to check it, if you don't have a meter. It's more than likely the valve though.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 23, 2009
  • 4 Answers
SOURCE: range igniter will not stop ticking after flame starts
I have a similar problem.
Look at this post
http://appliancejunk.com/forums/index.php?topic=4812.0
Good luck
if you find out what wrong with yours, pls email me at [email protected]
Thanks
Posted on Sep 06, 2009
EllaWatson25
  • 725 Answers
SOURCE: Whirlpool super capacity 465 - Oven won't light
This is your gas valve that is bad on this unit. Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
with your complete model number and we will get the correct part out to you asap.
We are available from 7 AM until 9 PM CST Monday through Saturday.
Posted on Nov 10, 2009
Whirlpool supercapacity 465 gas oven will not heat up all of a sudden
Does the igniter glow white hot? What is the complete model number?
Feb 13, 2013 | Kitchen Ranges
I have a Whirlpool Stove, model SF367PEYQ3. When we turn the oven to 'BAKE', it takes 1-2 minutes to light. When it does light, it lights with a small explosion and we can smell gas. I took up...
We're sorry to hear about your Range. Can you please email your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to [email protected] so we may look into this?
Jun 12, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
I have a whirlpool super capacity 465. The oven does not light each time I turn it on. It may take 30 minutestes for it to light at times. How can I fix this problem.
look at the color of the ignitor, if it is glowing orange, you need to replace it. it should glow white hot in order to open the gas valve to light the oven.
Oct 26, 2009 | Whirlpool GS460 Gas Kitchen Range
What does a bad starter on a gas oven act like or sound like? Our does not sound right it doesn't sound like the oven is lighting at the same time.
your ignitor may be glowing alright but not pulling sufficient amperage to open the gas valve properly, or fully. you will need an amprobe to test the ignitors current. typically it is in the 3.2-3.5 range or a little higher depending upon which model you have. your amperage range is listed on the sticker on the side of the gas valve below the oven.
it is hard to tell precisely as you did not list any model number to go by.
hope this helps,
best of luck,
ttfn
Oven Not Working
Your igitor mat be glowing but it is not generating the proper amps to ignite the gas. The proper solution is to replace the oven igniter
May 27, 2009 | Whirlpool GS460 Gas Kitchen Range
Broiler works, as do burners. The oven will not come on. Gas whirlpool range 2003 year. Model SF367LEKB
jdelvecchio5Does the igniter (glow bar) come on whenever the bake function is selected.?
If the glow bar does not come on the safety valve will not open - no bake burner. check the electrical harness first then Try changing the igniter (glow bar first) before changing the safety valve/regulator.
Dec 02, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Re:Whirlpool SF310PKE gas range
When the oven safety valve refuses to open and let gas through, it's almost always because not enough current is flowing through the ignitor. Often an aging ignitor will appear to be glowing pretty brightly but still won't draw enough current to make the valve open. The first thing to try replacing is the ignitor.
You describe your ignitor as "red and glowing" but oven ignitors normally get a lot brighter than "red" -- well into what I'd call yellow.
Dec 19, 2007 | Whirlpool SF310PEK Gas Kitchen Range
Kitchen Ranges Logo
79 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Archie Ferrarini
Archie Ferrarini
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
