PHILIPS HTS3450 DVD HOME THEATRE SYSTEM NO SOUND
I HAVE NO SOUND. EVERYTHING ELSE WORKS WOOFER HAD ELECTRICAL BURNING SMELL COMING FROM IT. NO SMOKE. WILL CHANGING THE CAPASITORS FIX THE PROBLEM OR DO I NEED TO DO SOMETHING ELSE?
THIS IS THE HTS3450 PHILIPS.
THANKS
TONY
Quiero saber como puedo ecualizar el sonido con el control manualmente
Posted on Oct 30, 2008
  • 20 Answers
You could try, the burning smell could be the caps. Give it a whirl, nothing to lose at this point!
Posted on Aug 11, 2008
I have got Philips Home Theatre 5.1 (DSP 25000) , but it is not giving expected sound. Right Rear speaker and Left Fornt Speaker are not giving any sound . Please let me know the solution. I have connected...
Firstly make sure you have connected the speakers to the main system in an proper order. Certain system's have the name of the speaker's mentioned at every output line which is at the rear of the system. If you would connect the wrong wires then it eventually would not play the sound. once this is done make sure that the wires of each speakers are split into two at both the ends. They are normally coded in red and black colours at the tip of the wire. Check if the red of the wire is connected to the red of the system and so on for all the speakers. So try removing all your connections and do it all over in a proper way.
Sep 12, 2010 | Philips HTS3450 System
Hi, I own a HTSS3455 Home Theatre system since 3 years and it worked without any complaints since then but since last month I am facing sub woofer issues ..when I increase the woofer base volume above 5...
Hi, kumar,
I am also using the same model but i got problem in DVD player but my speakers are working fine. I am from Pakistan and here i didn't find the spare part of MPEG main board card. If you wanna buy my Speakers or if you wanna sell ur DVD player contact me on sajjadzaidi@hotmail.com.
Aug 25, 2010 | Philips HTS3450 System
Philips Home Theatre System - no sound or power light on sub woof
reset the device to factory settings, it is written in your manual how to do this. If that doesnot work, unplug the powersocket for about 30minutes, it will cause an internal reset which might solve it.
Edgar
Jan 23, 2009 | Philips HTS3450 System
Installing help
check on www.philips.com and search for HTS3450, all setup details are available there.
Jan 02, 2009 | Philips HTS3450 System
My mom just bought this philips sound system and the subwoofer is not producing any sound. The other speakers work just fine but the sub woofer does not work. I was wondering if their was any call backs or...
Press the surround button on the Philips remote to see if the subwoofer will begin producing noise - the surround button switches the mode from simple stereo to full surround. I would test the surround button while watching a DVD, because not every tv channel is going to even produce surround effects. Good luck!
-Tha Mp3 Doctor
Dec 18, 2008 | Philips HTS3450 System
Philips hts 3450 home theatre system, dvd in player, won't come
Before you do what I am about to suggest, understand that doing so will void your warranty with Philips. Find out if the product is still in warranty before proceeding - if it IS in warranty, then get it replaced through Philips (even though it is a simple solution):
Unscrew the four main screws on the bottom of the main base that are keeping the main unit together. Open up the case, retrieve the disc. Make sure that you do not knock ANYTHING out of place - you must proceed VERY carefully. Rescrew the case. Voila!
-Tha Mp3 Doctor
Dec 10, 2008 | Philips HTS3450 System
Region Unlock code for Philips HTS 3152
Thanks dude,
Not sure which trick worked, but i did ur classic 7,3,4,4,6,6,0 trick, got no message from the player. So i did pressed 0000 after that. Still no message appeared. But when i pressed start....it worked!!!!!!
Thanks a ton!!!!!!!!!!!!!!!!!!!!!!!!!!!!! God Bless...
Sep 23, 2008 | Philips HTS3450 System
I bought philips 5.1 home theatre for PC it is not supporting
As I found somewhere on the internet; there are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #: 272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. Make sure you match the polarity properly when replacing. Your unit will be as good as new and will proibably last forever now.
Jul 02, 2008 | Philips HTS3450 System
Philips HTS3450 sound problem
Jun 09, 2008 | Philips HTS3450 System
523 people viewed this question
 Grubhead
Grubhead
