Question about ATI All-in-Wonder 2006 PCI Express , (256MB) (256 MB) PCI Express Graphic Card
Video playblack really slow when transferred to Computer
This is what I am trying to accomplish. I have video on my camcorder and I am using the connectors from the ati card to plug in my camcorder and then using Nero to capture that video. It appears that it records fine but then when I try and play it back after recording it it is super slow. I can't figure out what the problem is. Any help in this matter is greatly appreciated.
Thanks,
Chris
    Problem Solver:
  • 10 Answers
Most of camcorder was bundled with the cable and the driver..
There are 2 type of cable , first is usb , and the 2nd is firewire...
USB 1.1 is having 150 MBit/s while USB 2.0 have 480 MBit/s and Firewire maybe vary depends on the type..
Though you must have good specification of computer when you want to burn the video and make it readable to the CD/DVD player... or just want to play in your computer..
This is the specification .. you should check it whether it's match or not..
1. The processor.. It's better to have the Intel Pentium rather than AMD because your transfer take a long time to go.. to transfer the data.. AMD produces more heat than Intel..
The bigger clock of the Processor and mostly the bigger L2 cache memory of the processor is the better...
2. Harddisk
You must have a harddisk more than 80 GB because when you transfer the data from camcorder to your harddisk, it takes a large amount of disk space.. this also will reduce the performance of the playback , since windows will give you warning of low disk space...
You must have a harddisk with it's bigger cache memory especially 8 MB memory.. This will speed up the playback performance....
Your harddisk also must have the minimum spindle rate of 7200 rpm (this will accelerate the level of playback) The bigger spindle rate of the hard disk will always increase the reading level of your data which reside in it...
3. The amount of Memory ..
Make it sure at least you have 1 GB RAM
PS: Better to have DDR2 RAM because the higher bandwith...
Try to use the identical chip (not by brand) especaily when you use 2 kind of memory)
4. Mainboard ...
Use the intel chipset ,,..(as the north bridge and the south bridge).. frequently accelerate the performance better than sis or via..
Optional : find the dual channel memory bank and place the point 3 (2 identical memory here).. it will boost up your play back performane
5. The Graphic Card
Use at least 256 MB Graphic Card which have 8X data transfer rate... you can use PCI express with X16 when your motherboard support it..
Hope this thing will solve your problem...
if it doesn't email me at [email protected] and don't forget to vote
Posted on Aug 11, 2008
SOURCE:
How do i get footage off of my camcorder and onto my computer?
Unfortunately, it is not possible to transfer video from your camcorder to your computer directly, The camcorder id an Analog device and the computer is digital. You would need some sort of analog to digital converter to accomplish this. There are several devices on the market that will suite your needs, however they can be expensive. The easiest way to achieve this would be to have a " Video Transfer" service put the videos on DVD's and then transfer them to the computer for editing.
If this has been of any help to you please give a positive vote.
Aug 06, 2010 | Sony Handycam CCD-TRV308 Camcorder
Unable to transfer video information onto PC ACER ASPIRE using windows Vista for editing by windows movie maker. Interface on PC is via USB. If software driver for firewire or 1394 interface is available...
If you want to use the USB cable to connect the Camcorder to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Good Luck!!!!!!!!!!!!
Sep 28, 2009 | Sony Handycam DCR-TRV16E Mini DV Digital...
Camcorder SONY DCR-TRV25E, COMPATIBILITY window vista
Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable.
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer using i.LINK cable.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
If you are using an i.LINK cable then:
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
Good Luck!!!!!!!!!!!!!!!
Sep 20, 2009 | Sony Video Cameras
Cant transfer videos to pc
Option 1:
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Option 2:
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
Option 3:
Sep 17, 2009 | Sony DCR-TRV285E Digital-8 Digital...
Video is choppy when transferring flipvideo
I have the exact same problem ... I have a Compaq ... Vista Home Basic, plenty of RAM 1.8GHz ... FLIP told me the exact same thing ... it's exTREMEly frustrating.
Jul 23, 2009 | Pure Digital Flip Video Ultra Camcorder
Video transfer
If you're using a Windows Vista Operating System it'snot possible to transfer the videos from the Camcorder to the Computer using the USB connection. The videos from the tape camcorders cannot be transferred to Windows Vista Operating System as there is no USB Streaming ooption available on the Windows Vista Operating System. The Camcorder uses the USB Streaming function to transfer the videos to the Computer. You may wish to purchase a i.LINK/Firewire cable to connect the Camcorder to the Computer in order to transfer the videos from the Camcorder to the Computer.
or
There is an update for driver on the Sony website to transfer the videos from the Camcorder to the Computer using the USB cable.
http://support.sony-europe.com/dime/downloads/downloads.aspx?site=odw_en_GB&m=DCR-HC42E&f=usbdrven_vista
You may also try installing the driver update for the Camcorder. The i.LINK cable gives a better video transfer qulaity than the USB transfer. The i.LINK cable used to connect the Camcorder to the computer depends on the number of pins available on the i.LINK/FIREWIRE port on the Computer. The i.LINK port on the Computer is a D shaped port which is labelled as i, DV, IEEE1394 and Firewire.
Jun 07, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Transfer video files from camara to pc
You have a search over the pc you can find the find the transferred files .
The location can be different in pc .
Oct 25, 2008 | JVC Everio GZ-MG21 Camcorder
No sound
Hi , try to play your old video taken if still have no sound , if the same no sound the audeo system has a problem.
If having sound in old video collection , the tape that you are using now are having deffect connot record sound. replace a new tape, and try record again.
Jan 15, 2008 | Sony Handycam DCR-TRV22E Mini DV Digital...
Transfering video to Mac
Digital video on the ZR400 is transferred to a computer only via the DV out port, which will connect to a firewire port on a PC or a Mac. USB will not transfer video, only images to and from the card.
Nov 13, 2007 | Canon ZR400 Mini DV Digital Camcorder
Can not transfer to computer
Hi, I had the same problems 'till I picked up this: Koutech PCI to 1394a Card Model KW-582V2 It apparently contains some Texas Instrument hardware (or drivers?) that will make the camcorder transfer with ease! It did the trick perfectly and is really low in price! Sorry, not a real technical answer, but this is what worked! Scott
Dec 06, 2006 | JVC GR-D270 Mini DV Digital Camcorder
Open Questions:
Samsung Wireless Printer customer care number%%[+l{855^26O0O64}%%:~NumbER USA Vuots Samsung Wireless Printer VuLogin customer care Number +[185526O0O64]VuLogin Samsung Wireless Printer tech support number USA Repair service center to resolve all Samsung Wireless Printer tEcH SupPoRt pHoNe nUmBeR products. Samsung Wireless Printer is an American multinational company which was founded by Michael Samsung Wireless Printer using its company headquarters in Round Rock, United States of America. Contact Samsung Wireless Printer for Setup & Installation Samsung Wireless Printer Setup Free & Installation Samsung Wireless Printer TECH FREE number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Samsung Wireless Printer Connect, Samsung Wireless Printer TECH Free Phone Number you'll be searching out Samsung Wireless Printer Connect setup as well. So, here we're with all cthe setup process and for your to Samsung Wireless Printer Connect. Get Samsung Wireless Printer Setup Instant Free Samsung Wireless Printer TECH FREE Phone Number Usually, the setup TECHnique takes a number of time. One TECHnique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may locate the approaches simplified tdako help you even if you aren't TECH-savvy. Let us undergo the method of Samsung Wireless Printer Connect setup for Windows and for Mac. So, right here we go vikki TALATUMAS
Oct 18, 2019 | Samsung Computers & Internet
Samsung Wireless Printer tEcH SupPoRt pHoNe nUmBeR:~{-1{85526O0O64^-} Vusary Samsung Wireless Printer tech Support Number +1{{85526O0O64}VuLogin Repair service center to resolve all Samsung Wireless Printer customer service phone Number products. Samsung Wireless Printer ROUTER is an American multinational company which was founded by Michael Samsung Wireless Printer ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Samsung Wireless Printer ROUTER support number, and selling of computer-related services and products. Samsung Wireless Printer ROUTER Tech Support Phone Number Recently, Samsung Wireless Printer ROUTER has been named the number Samsung Wireless Printer ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, Samsung Wireless Printer ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a Samsung Wireless Printer ROUTER Service Tag or a Samsung Wireless Printer ROUTER Get Samsung Wireless Printer ROUTER Technical Support Phone Number and Customer Services. Samsung Wireless Printer ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Samsung Wireless Printer Tech Support pHoNe%%[+l{85526O^0O64]:~%%NumbER Vujsery Samsung Wireless Printer TeCh SuPpOrT Number +[185526O0O64]VuLogin Samsung Wireless Printer customer service phone Number Repair service center to resolve all Samsung Wireless Printer products. Samsung Wireless Printer is an American multinational company which was founded by Michael Samsung Wireless Printer using its company headquarters in Round Rock, United States of America. Contact Samsung Wireless Printer for Setup & Installation Samsung Wireless Printer Setup Free & Installation Samsung Wireless Printer TECH FREE number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Samsung Wireless Printer Connect, Samsung Wireless Printer TECH Free Phone Number you'll be searching out Samsung Wireless Printer Connect setup as well. So, here we're with all cthe setup process and for your to Samsung Wireless Printer Connect. Get Samsung Wireless Printer Setup Instant Free Samsung Wireless Printer TECH FREE Phone Number Usually, the setup TECHnique takes a number of time. One TECHnique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may locate the approaches simplified tdako help you even if you aren't TECH-savvy. Let us undergo the method of Samsung Wireless Printer Connect setup for Windows and for Mac. So, right here we go vikki TALATUMAS
See all ATI All-in-Wonder 2006 PCI Express , (256MB) (256 Questions
ATI All-in-Wonder 2006 PCI Express , (256MB) (256 MB) PCI Express Graphic Card Logo
71 people viewed this question
Top ATI Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
