Question about Whirlpool Washing Machines
Hi I have a Whirlpool 8255e super capacity Plus Washer commercial quality top loader, My problem is it Sometimes does not finishing cycles, it will either keep washing or spinning, have tried different wash cycles same effect! I think its the timer. The machine is 5 to6 years old and apart from the rubber drive thingy going twice has been great washer
    Genius:
  • 1,028 Answers
Sounds like timer hanging or bad timer motor ..in either case only solution replace timer
Posted on Aug 11, 2008
Whirlpool super capacity plus (commercial quality top loader) does not spin on all settings and does not spin fast enough
sounds like you have a worn out clutch. depending on model it could be an easy fix. would need to know model number to know for sure.
Apr 03, 2013 | Whirlpool Washing Machines
How to remove aggitator from center of machine to clean inside of it, there seems to be little bits of whatever coming from there its a whirlpool super capacity plus 8255e commercial quality
Pry the top lid off the agitator.
Remove the plastic shield inside.
Use a 7/16 socket and extension to remove the bolt.
Pull the agitator off the shaft.
Mar 04, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Have a Whirlpool Super Capacity washer in which the drum will tilt during the wash cycle and spill water. If held to center, there is no leak, and the cycle completes without difficulty.
Could you tell me what the life expectancy for this washer might be and does it have a good track record. (Mom gave me one) Whirlpool Super Capacity Plus 7-Cycle 2-speed. 3.2 cu. ft
Mar 02, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
What would you recommend for a good super capacity top loader washer? My 15 year old Whirlpool just died. Don't really trust electronic controls, reviews of he top loaders are so mixed, I am unsure. Also...
To be honest I really don't trust electronic controls due to the fact that the majority of the repairs i do on front loader machines has to do with the electronic controls. In my opinion top loaders are more reliable. they get the job done. If you were to get a top loader i do recommend whirlpool, even though i agree that the quality is down. I also like the whirlpool cabrio, its a top loader but has electronic controls. it uses less water and soap just like a front loader. Whatever you do decide to purchase, I highly recommend that you purchase the extended warranty. This way if there is ever a problem, you know that you are covered.
Feb 03, 2011 | Washing Machines
Turns on but doesn't heat up
most likely heating element needs to be replaced.most can be accessed by removing back panel. also a thermostat switch may be faulty.
Aug 09, 2009 | Dryers
Whirlpool 8255e makes ''whirry'' sound when pumping - not spinning
there is probobly something small jammed into the pump
common for that sound would be a underwire for a bra.
is it still draining ok?
May 26, 2009 | Whirlpool Washing Machines
Can't find Lint filter on a Whirlpool 8255e super capacity Plus Washer commercial quality top loader,
The Topload whirlpools are designed to take the lint out by reversing the water to drain out.any lint should be drained out.
Nov 01, 2008 | Washing Machines
Cannot find the model number on my Whirlpool washing machine. It is a top loading machine, with such features as: 4 Load size, 4 Tempature settings, 8 cycles, 4 speed combinations, commercial quality....
If this was a scratch and dent model, model number may have been removed prior to sale. If not, you should find it on the back edge of the washer at the very top as you look over the back of the machine. If you can't find a model number, bring the part(s) you need to a servicer. They may be common parts or there may be some identifying numbers on the parts themselves. Good luck.
Sep 01, 2008 | Whirlpool Washing Machines
WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
680 people viewed this question
Dan Webster
Dan Webster
Sal De
