How do i record a dvd i can play in a regular dvd player from files on my computer?
  • 65 Answers
For this i would suggest to use a avi to dvd converter program. windows vista may already provide you with a program for this. however i would suggest to use imTOO it supports the features your looking for, thier is a free trial so you can try b4 you buy. i've had very little problems with this program and it's quite user friendly.
Posted on Aug 11, 2008
I am able to copy my vhs to dvd on this device and it will play back on this device but the dvd's will not play on any other player. Can you help with this please?
Not completely sure about the "device" you used to make the recordings, but most likely the reason for them not playing on another player is that whenever you record DVDs, in order for them to be readable by regular players, the DVD must be "finalized". Once that is done, and the device you used to record the DVD should be able to do that, then you should be able to play them on a regular DVD player. Know this, however, that finalizing the disc means that no more data can be recorded to it.
Sep 01, 2015 | Televison & Video
I have a JVC DVD & HDD video recorder (DR-MH30S). I use it regularly to record to hd, but cannot dub successfully to dvd. The dvds work in that machine but not in any other dvd players, or even my...
are you able to atleast view and play the files in your computer?
if so then there is no problem with the recorder.
what is the format in which it records the files?
Sep 18, 2008 | Televison & Video
This is quite common of older players. Some only work with DVD+R discs and others with DVD-R discs.
Some player also does not read recordable discs (an early form to try prevent piracy)
Also make sure if recorded on your Recorder, that the disc is finalized before you try to play it on an older player. (See your menu / manual on the recorder for the procedure)
Feb 28, 2010 | Sony RDR-VX515 DVD Recorder/VCR
I cant get it to play the VHS
What do you mean can't get to play the VHS? did you mean after you record your video from VHS and trying to played using the regular player then it will not played? Had you try to used another brand of blank DVD disc? if ever that your video record and save to your computer had you try to used any dvd player program? such win dvd?
Dec 04, 2009 | Pinnacle Dazzle DVD Recorder
Did not burn dvd
The DW-100 burns files in the same format as they were originally recorded by your camcorder. The Canon Vixia HG-21 records in AVCHD--a high-definition format--which is completely different from standard-definition DVD and which is not compatible with regular DVD players (even though the disc itself is a standard DVD-R). As it states in the manual for the camcorder, "High-definition (AVCHD) discs created using the optional DW-100 DVD Burner can be played back only with AVCHD-compatible DVD players."
The DW-100 is really more for archiving your files in their native format than for creating standard DVDs that can be played on regular DVD players. Regular (standard-definition) DVD players can't play AVCHD, although many Blu-Ray players can. Unless you use a Blu-Ray player that supports AVCHD playback, there are two solutions to your problem:
1. If you want to keep your recordings high-def, you can view them by playing them back with the DW-100, which must be connected to your camcorder via the USB cable, then from your camcorder to your TV via an HDMI cable.
2. If you want to have standard DVDs that you can play on any DVD player, either import the files to your computer and convert them to standard-definition using video-editing software, then burn them to DVD with your computer's DVD burner, or connect the analog output (component=better, composite=good) to a stand-alone DVD recorder (i.e. not the DW-100).
I've used the route of Vixia HF-10 camcorder > composite output > Panasonic DMR-ES25S DVD recorder (about $65 used on eBay) with pretty good results when I've wanted to give videos to relatives who don't have Blu-Ray players. You just have to make sure to set the camcorder 's analog (composite) output to 480i so that it formats the picture in the right aspect ratio, or else the 16:9 image will be squeezed to 4:3 instead of letterboxed.
Hope this helps. Good luck.
Mar 19, 2009 | Canon DW 100 DVD-RW Burner
I recorded my movies on the dw 100 but now i can't grt them to play on my dvd player
The DW-100 records discs based on the format they were originally recorded.
If your camera is recording HiDef videos than the discs this unit creates will be viewable on a Blu-ray disc player.
If your camera is recording in Standard Definition (ie. NOT HD) then I believe that the discs will work in regular or upconverting DVD players.
My Canon camcorder does not record in Standard Def so can't quite vouch for that last comment though.
Jan 06, 2009 | Canon DW 100 DVD-RW Burner
Photos I burn on computer jpeg image dont play on philips recorder dvdr recorder
alot of DVD players wont play jpeg files try saving the pics as a gif or other type of file to see if the DVD player will play them
Apr 07, 2008 | Televison & Video
Mini dvd can be burned on a regular dvd, but cannot be played
convert them to normal format using file convertor or record in VR format instead of Video format
Oct 24, 2007 | Canon DC210 DVD Camcorder
No picture
[I am assuming that the recorded disc was not made using the DVD recorder]. It's most likely that the video portion of the file is encoded in a format that is not supported by the DVD recorder. The player only supports DivX, JPEG, and MP3 formats. So try transferring the file on the disc to a computer and encoding in a supported format. You can use free online services such as or to encode media files into different formats.
Jul 29, 2007 | Panasonic DMR-EZ17 DVD Recorder
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
Computers & Internet Logo
David Payne
David Payne
