Leave the starter alone, If you turn the key and it does not make noise then you are going to need a ignition switch, electrical part, the ignition switch the electrical part it is located on the steering colum under the dash. look under the dash along the steering column now turn the key as you cycle it do you see a rod moving? where that rod connects to is the" electrical ignition switch part" here I made a drawing
