Question about Whirlpool Gold GB2SHDXPS Stainless Steel
Whirlpool Gold Botom Mounted Refrigerator is not functioning in the main compartment
Our Whirlpool Gold Bottom Mount Refrigerator,model--GB2SHKLLS00 is not refrigerating the main compartment. The freezer section is being cooled and is just fine. However even after unpluffing and restarting the refrigerator and cleaning all the vents in sight, the main compartment refuses to cool. However, the lights in the main compartment are on, and function normally. However, on the same note, the refrigerator's noise level is the same as when it was operational. Any help would be appreciated, thanks in advance.
Pradip
  • James Helmer
    James Helmer May 11, 2010
    Both the refrigerator and freezer section are cooled by the same system. If the freezer is working fine and the refrigerator section is not cooling the air to the refrigerator is being held back in the freezer. Check the freezer for frost buildup on the back wall. This would indicate that your defrost system is not working right and the frost buildup is stopping the air flow to the refrigerator section.
Frost accumulation in duct that leads to the freshfood section.
Posted on Sep 22, 2008
Can you tell me why please?
All the big cooling happens inside freezer compartment. Freezer gives little cool air to fridge compartment. Now when the vent blocks that little cold air cannot go into fridge compartment. Thus your freezer works good but not fridge compartment. Milk goes bad but frozen meet keeps good.....
Vent freeze up either due to defrost problemt, defrost drain line problem, Evaporator fan problem or even can be your damper motor not opening due to unit failure or frozen damper door.
Sep 19, 2014 | Whirlpool GX2FHDXVY Gold Stainless Steel...
Whirlpool Gold Model # GI5FVAXVQOO French door Refrigerator with ice through door is frosting up in the freezer.
your defrost drain has clogged, normal self defrost cycle should be removing water via a drain tube leading down behind unit and evaporating away. however if you were to look behind refrig in compressor compartment youll see a "drain tube" that has what appears to be a black "duckbill" grommet attached..it has more then likely failed be gumming up and preventing water to drain through.if you remove this and install part number "w10619951", should solve your problem... youll need to clear frozen drain from inside unit as well, directions i believe are in the part packet
Oct 28, 2013 | Whirlpool Gold GI5FVAXVQ 25 Bottom Mount...
Hello, We have a Whirlpool Gold bottom freezer
I don't know about Whirlpool refrigerator freezers, but my Amana has a temperature control in the freezer that regulates the overall cooling, and then the control in the refrigerator compartment controls how much of the total cooling is sent to the refrigerator section. My advice would be to lower the temperature setting of the freezer, and see if the temperature lowers in the refrigerator as well. Also, you can go to the Whirlpool website and they can help you further.
Aug 02, 2013 | Refrigerators
The Whirlpool Gold refrigerator is not cooling and the bottom freezer has ice formed on the back of the freezer. I purchased the refrigerator in February 2009.
If you can hear the fan running in the freezer you have a defrost issue. Depending on the Model number it can be a timer, adaptive defrost board, a bi-metal themostat, or heater.
May 26, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Aug 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold GS6SHEXNL - Freezer works, Refrigerator cools but display and lights do not work.
From about an hour of searching your refrigerator I found that the problem is in the control board mounted on the back of refrigerator. Visit this link below and enter model number GS6SHEXNL into the search model and parts search feature. When you get to your refrigerator on left of screen is different prints, chose #11 and you will #18 in picture. Click on link below and following links to support this problem. Model GS6SHEXNL Part Number W10135090
http://servicepartstec.blogspot.com/
refrig-problem-5577/">http://www.diychatroom.com/f47/whirlpool-refrig-problem-5577/
If you need more help, just let me know, Thanks, Sea Breeze
Apr 22, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Interior water leak on model ET18PKX6HB1 whirlpool refrigerator
The drain is clogged up. Check the clear plastic line that goes from the back to the drip pan on the bottom of the unit.
Mar 30, 2009 | Whirlpool Refrigerator Inverter Box -...
Larder section of fridge not functioning
check the drain that is inside of the freezer compartment at the bottom. you may have to disssasemble the covers to get to it. if its clogged the water turns to ice real quick and blocks air to the refrigerator
Dec 29, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold
Your drain was clogged. look for the drain funnel then remove the dirt.
Jun 07, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold GB2SHDXPS Stainless Steel Logo
282 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
