Question about Watches
Eddie bauer EBTEK Titanium wtch #0131CE
Any idea how to get the back off this to change the battery? It has 6 slots on the back, but I can't seem to get it open.
Thanks,
  • 109 Answers
Use a needle nose pliers and turn counter clock-wise. If you find it hard to open still you may have to put it in some kind of vise and then turn it. If you still have problems PLEASE don't hesitate to write back and I will be glad to help you! Good Luck!!
Posted on Aug 11, 2008
SOURCE:
Folding instructions
You may have to fold it tightly, then squeeze out trapped air before it will fit
Jun 14, 2013 | Eddie Bauer First Ascent Stargazer 3 Tent,...
Skips time
If it is not a feature built in to the watch to save power when it needs winding, I would say it has a bad gear wheel inside.
I would go here, join, and ask in the Rolex Forum,
http://www.watchuseek.com
These guys are really knowledgeable.
Jun 15, 2010 | Rolex Daytona 116520 Wrist Watch
How to change the battery on a Large Square Digital Ebtek watch?
You will either find a very small lip that accepts a prying tool or you may see some indentations for a caseback wrench to unscrew it. Any jeweler or watch shop (including Sears) will change the battery for less than $8 and ensure that no damage is done and that the gasket that provides water resistance is replaced (insist that they do!). DO NOT reuse the gasket even if it looks undamaged. It will not keep water out if it is reused.
Apr 10, 2010 | Watches
Cannot get the back cover on my eddie bauer watch after replacing battery
Watch makers/technicians use a special press to replace the back. You can get these presses but the cost can be more than it is worth.
Since the watch is most likely water resistant and you will have to go to a watch maker/technician to replace the back anyway I recommend having the rear seal inspected and replaced if needed and having the watch pressure tested to be sure that it is sealed to factory specifications.
Sep 24, 2009 | Watches
Eddie bauer watch runs slow
This usually means the battery is dying. Usually the backs on these are very tight, and the back has to be taken off to replace the battery. You might be able to get the back off without damaging the watch, but you probably will not get it back on without breaking the crystal. Best thing to do is take it to a reputable watch repair place or jewelry shop and have them replace the battery for you. Before they begin, make sure they are willing to replace the crystal for free for you if they break it!
Aug 06, 2009 | Watches
Eddie Bauer wireless thermo clock - Time zone problem
TIME ZONE SETTING
The cefault time zone is PACIFIC. lf your location is not in the Pacific zone, set the
time zone as follows:
1. In normal time mode, press the "[,4ODE" key to enter the alarm time mode. 2. ln aiarm time mode, press and hold the ADJ . 'Cl"F" key for 2 seconds to enter
the time zone setting mode.
3. Press ihe "ADJ "C/'F" key to select the proper time zone: P=Pacific
M=Mountain C=Central E=Eastern 4. Press the f,'lODE key to save and exit the time zone setting mode, or let it exit
automaiically 30 seconds later without pressing any key.
Mar 08, 2009 | Watches
Get the back off my eddie bauer watch
when you look at the back are there three small rectangular indents evenly spaced on the edge on the back? If so you'll need a special tool for opening waterproof watches. the tool adjusts to fit the three indents then press down as you turn counterclockwise. you can find the tool on amazon.com or your local jewelry store. make sure the gasket is in place and not damaged before screwing the back on.
here is a link to the tool
http://www.amazon.com/Pavilion-Professional-Waterproof-Adjustments-Caseback/dp/B000K3SK0Y
Jan 16, 2009 | Timex Expedition 84601 Wristwatch
Can't set time on my Eddie Bauer watch
Nothing on the net, so, you will have to go back to the store.
Sorry....
Dec 20, 2008 | Watches
Eddie Bauer watch.
these watches are waterproof so the stem is screwed down to seal out water. Try turning the stem to unscrew it somewhat , then pull out the stem to set.
Jan 05, 2008 | Watches
Watches Logo
1,297 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
