Download from here all patch done for all windows fast game play with Unlimited Ammo and All mission unlocked
100% works see Video more more info or Download from here Downlaod
https://destyy.com/qCcI06
SOURCE: slow file transfer
What is your connectivity to the SAN? fiber or iSCSI? Have you checked the management tools to see if there are any errors on the data paths? If using iSCSI and the SAN and server are in the same network segment, make sure the default gateway is empty for the iSCSI connection. Look at the routes on the server to make sure the traffic is not leaving the subnet through a router and back to the SAN, and vice versa. If fiber then you'll have to use the tools given to check for errors. Ken
SOURCE: pc wor slow
you could have a driver problem, but i would expect you to require more than 256MB of ram work along side a dualcore processor, you should have atleast 1GB ram.
SOURCE: Mouse Pointer freezing on Vista Intermittently
try to install the service packs and updates. You might want to save the downloaded files while you're at it. In case it works you need those for the other 2 machines. hope it helps
SOURCE: Mouse Problem in Project IGI
Sounds like to me you need a new mouse. Or if it is wirless you must have the infrared receiver closer to your mouse.2) check your device manager and see if your mouse has a Yellow ? or ! mark next to it.If so right click on the mouse listing and click repair or update and or uninstall then reinstall your mouse last. This will fix it if it is not gone!!!
Great Luck!!!
I’m happy to help further over the phone at https://www.6ya.com/expert/phillip_293d34ebcf028794
