Question about Microwave Ovens
Panasonic Microwave door Will not open
1/ What do you mean by the general term "HOUSING?"
2/ I want to get the Control panel off to get access behind it, to get at the door lock, any Idea
  • leojay Apr 30, 2009
    I have an over the range mount Panasonic Microwave and the door will not open. It seem like the door switch is strip or some is not catching. Do I have take it down? model nnp295w
    Genius:
  • 2,920 Answers
Tilt the microwave backwards and see if there are screws in the bottom part of the control panel if so take them out and lift up on the panel.there may be 2 screws holding it in place.
Posted on Aug 11, 2008
You guys are all retarted....
Posted on Oct 12, 2008
2 Suggested Answers
  • 2920 Answers
SOURCE: Panasonic door won't open
the main cover of the microwave needs to be taken off so you can get the door opened and then you should have access to the screws that hold the door together. the housing is the main part of the mw and once its off you should be able to open the door from the inside and thus be able to work on the door latch..please rate me thanks
Posted on Aug 10, 2008
I have a Panasonic Microwave Model NN-SD277. How do you access the workings of the door opener button? It is broken so the door won't open.
You have to remove the outer cover, the plastic lift levers are behind the door open button / lever. Caution!, panasonic discontinued a lot of those and getting a replacement part can be hard at times. Dont waste your time trying to glue it. After watching people try to glue or epoxy those cheap plastic parts for so many years. I have to warn folks to not waste your time trying. .It will not hold!!!! Look online and try to find a replacement part somewhere. It will be one of two parts. the door open button you push, or the door open lever that the front button pushes against. If you unplug the unit and remove the outer cover simply look behind the front control panel and when you push the button to open the door you will see where it is supposed to lift to open the door. The broke part is your problem, may be a piece laying in the bottom.
Aug 14, 2017 | Panasonic Microwave Ovens
I have a Panasonic MW Oven (NNS255) I Cannot open the door. How do I get access to behind the control panel to fix whatever is broken
you need to take the housing off the microwave to get to the door latch..once you get it open you should be able to find access screws to take the door apart to see whats broken.please rate me thanks
Aug 10, 2008 | Panasonic Microwave Ovens
Where is the fuse on KitchenAid model KHMS2050SSS microwave?
Fuses in microwaves are generally located behind the control panel. They can be close to the panel, midway back in the microwave case, or all the way back on the rear wall of the housing. Accessing the fuse will usually require removal of the entire outer case, and in some instances, the removal of additional interior panels. If you decide to do the job, be sure to replace the fuse with one exactly like the ceramic one you find in there. Glass fuses are not designed to handle the power that goes through these ceramic fuses.
Oct 10, 2014 | Microwave Ovens
Panel problem
Hello
Unplug the microwave from the wall outlet prior to disassembling.
Open the microwave door. Remove the screws securing the grill above the door opening to the microwave. Remove the grill.
Remove the screw located at the top of the control panel, which is now visible with the grill removed.
Lift the control panel up to release the tabs securing it in place. Move it away from the microwave.
Look at the rear of the control panel to any disconnected wires that may have caused the control panel to stop functioning. If wires are disconnected, reconnect them, reassemble the microwave and determine if the problem is still occurring. If the problem still occurs, replace the control panel.
Transfer the wires from the old control panel to the new control panel.
Move the panel back against the microwave's control panel housing. Slide it down to lock it into position.
Install the screw at the top of the control panel.
Replace the grill on the top of the microwave. Secure it using the screws that were removed.
Restore power to the microwave.
Oct 04, 2011 | Panasonic Microwave Ovens
Is there an internal light in the NNT664SF
Yes, there is a light on the right hand side of the microwave (looking at the control panel). It is located directly behind the control panel and may be seen with a flashlight looking inside the door through the perforated metal housing. Four special hex-with-stem screws must be removed from the cover to access it, along with one standard Phillips head screw on the side. Once the screws are removed you must slide the cover toward the back about 1/2" before it will be able to tilt up and be removed.
For safety reasons make sure to unplug the unit and allow it to discharge before removing the cover. Also make sure to not touch anything you aren't intending to work on - it could be carrying power from the capacitor, which is like a battery, and might not be discharged while you are poking around inside.
I am currently seeking out a replacement lamp for mine. I could not find one at any of the local hardware stores as this has a proprietary base and the bulb is not removable from the base. I will be looking on ebay and elsewhere.
Oct 02, 2010 | Panasonic NN-T664SF Microwave Oven
Panasonic microwave oven
Microwave fuses are normally located either on a filter board near where the power cord comes in, behind the control panel between the door switches, or behind the control panel in a hodler, sometimes on the floor of the chassis.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find an authorized Panasonic servicer here.
You can order Panasonic parts from Tritronics, but if you don't find what you're looking for there, try here.
Nov 04, 2008 | Panasonic NN-H264 Microwave Oven
Aug 10, 2008 | Microwave Ovens
Microwave Power Blew Out - Kenmore Elite Model 721.63763300
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 09, 2008 | Microwave Ovens
Panasonic Micro-combi
You mean it doesn't heat?
Any other symptoms or problems?
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
To order Panasonic parts see http://www.pasc.panasonic.com/epartr ; To download a Panasonic manual see
http://service.us.panasonic.com/operman ; to find an authorized Panasonic servicer, see
http://www.pasc.panasonic.com/WhereTo/FindServicer.asp?Pass=1 ; For FAQs, see http://service.us.panasonic.com/faq/faq.aspx
Aug 28, 2007 | Microwave Ovens
Stuck Microwave door
In most cases this is due to a broken door opening lever or loose or broken door latch / hook parts. They can only be accessed and examined if the cover is removed from the microwave. In many over the range models, you can access the door parts by removing the control panel assembly. Sometimes you may be able to get it open by pushing up gently on the bottom of the door while pushing the button, in case you need to empty it.
Jul 30, 2006 | Whirlpool MT4070SK 700 Watts Microwave...
Microwave Ovens Logo
254 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
