Question about Olympus Cameras
I pressed the "Menu" button on my camera and it froze. I took out the battery, thinking the battery was dead, and now, even at fully charged, the camera won't turn on. I brought the camera only 8 months ago.
    Master:
    Sergeant:
  • 398 Answers
Contact cusomer support on their web site. Be sure you have serial number and date of purchase.
Posted on Aug 11, 2008
Why does shutter error message appear when button pressed?
If the shutter has 100K operations then the camera may be due for a replacement (not worth repairing).
Please make sure you have a fully changed battery in the camera. If the camera does not have a battery icon anywhere showing a low or dead battery then you have a camera that should be sent to a Nikon Authorized service center. They can clean and repair your camera. They will; QUOTE the repair before you pay. All you are out is shipping costs.
Aug 06, 2015 | Nikon D90 Digital Camera
Olympus stylus 1 just froze with lens extended. I took battery and card out for 2 hrs. and still no power.
Try this, set the dial to P, then open the battery door and then press the Menu button and OK button together for about 5 seconds. If you see something in the screen like Olympus? Then press the Menu and OK button together again for another 5 seconds, this is a hard reset and hope it fixes your problem?
Nov 29, 2014 | Olympus Stylus Cameras
Canon PowerShot G1: If battery pack is fully charged, can a dead Button Battery (CR2016) cause the camera to not power up? Thank You
No. The coin battery only powers the memory for the camera settings such as date & time. I suspect you have a chip failure and will need to send the camera off for repair. I know, I know,.... these repair places are a rip-off because they quote a flat rate for repair, even if it's a $3.00 chip set.
Mar 28, 2011 | Canon PowerShot G1 Digital Camera
Playback and menu buttons freeze camera
This is a circuit board problem, return the camera for warranty repair replacement.
Please rate my help++++Thanks for usinf FIXYA
Mar 24, 2010 | Nikon COOLPIX S570 Digital Camera
SanDisk Sansa froze on song screen, wont unfreeze
Make sure the player is fully charged. 1. Connect the player to your computer. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary.
To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Then try and see if it will come on with out the battery hooked to your computer, which I see you have done but did you change modes MSC to MTP . next delete the song it keeps hanging on and re-copy it back on to the player from a different folder or re-rip it from the CD and copy it into a new folder then re-copy to the player.
Feb 02, 2010 | SanDisk Sansa E280 MP3 Player
Four hours old nikon l100 is freezing. also videos
Are you using rechargeable batteries and are they fully charged? If so, take the camera back.
Nov 13, 2009 | Nikon COOLPIX L100 Digital Camera
NIKON D80 MY CAMERA IS DEAD
if after replacing the batteries with new ones or freshly charged ones your camera does not start up, high chances that something internal has failed - that needs some professional checks to be done. The cam is built to identify and report most issues that can be corrected by the user. so if it does not turn on, chances are you need support from a camera repair shop. (Alt : one step that you already tried could have helped is the factory reset - there should be one or two buttons on the cam that needs to be pressed together to reset the cam)
Sep 22, 2008 | Nikon D80 Digital Camera with 18-135mm...
Camera Frozen
I tried Option No.1 successfully when my Panasonic DMC-FZ7K froze once:
Option No1:
1. Try turning the camera on with the battery inserted.
2. Now remove the battery while the camera is on.
3. Flip the switch on the camera to off, then insert a fully charged battery. (Make sure that the battery's orientation is correct. Also make sure that the battery being used is not damaged).
4. Now flip the camera's switch to ON again.
Option No. 2:
If you can open the Setup menu then the camera can be reset which might help:
Turn on the camera.
1. Press MENU SET.
2. Press the left arrow button.
3. Press the down arrow button.
4. Press the right arrow button.
5. Now, press the up arrow button several times until the menu item named RESET is highlighted. Push the right arrow button and then select and set YES when the camera asks to be reset.
Oct 18, 2007 | Panasonic DMC-FX07 Digital Camera
Cameras Logo
69 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
