Question about Electrical Supplies
Double spool on Weed Wacker
After trimming a short time with the weed wacker, both spools go back inside the weed wacker even if you click it on the ground every so often.
How do I keep the spool from going back into the weedwacker
thank you
  • Anonymous Sep 27, 2008
    how do you add new line
This isn't a solution to the problem. However, I think you should talk to someone at Home Depot or Lowes or wherever you bought the model, and see if the string is in there correctly; if it is, then u'r weed wacker must have some other mechanical problem. Sometimes it is just best to buy a new one. The more expensive models are the best.
Posted on Oct 02, 2008
SOURCE:
I need to take spool housing off to get grass out of GS900 B&D weed wacker
usually can turn backward to get ahold of ends with small pliers and pull out .the housings are a real pain to get off and back on .
Oct 28, 2015 | Garden
Worx electric grass trimmer / edger wg116 restring. Need this one not 117.
Demonstrated on a Worx String Trimmer - YouTube
? 3:55
www.youtube.com/watch?v=fFt3a3St54U
Jul 9, 2014 - Uploaded by EricL5150
This is a video on how to replace weed wacker string trimmer line in a string trimmer/weed wacker. ... This is done on a Worx string trimmer but the process is pretty much the .... How torestring dual-sided spool lawn weed eater trimmer with ... Worx56volt Cordless Trimmer Edger Review & Demo Video ...
Sep 18, 2015 | Worx Garden
The line on the B & D Electric Weed Eater has broken off. I can take the Orange cover off, but I do not know how to get the spool so I can continue weed eating.
Not avoiding the answer but if you google (" re-string a weed wacker video?" ), you can watch a video of how to do it, which may be a lot easier to understand when you see it.
Jun 30, 2011 | Black & Decker Vacuums
Can't remove spool from Black & Decker GH1000 weed wacker
UNscrew the cetral screw with a flatheaded screwdriver, then put the flate blade of the screwdriver in through the side slot where the cap clips in, and gently pry up on the spool from underneath it.
Sep 03, 2010 | Black & Decker 14" Grass Hog Xp...
How do you get the spool off of a gas (31cc) ryobi weed wacker? The string is stuck up in the spool and I can't get it out.
The knob on the bottom unscrews, and the spool comes apart once you get that off.
Mar 27, 2010 | Garden
Wind string on Spool
Most weedeaters have an arrow on the spool. Look at both ends, you'll probably find the arrow. Put your line into the hole and wind the line in the direction of the arrow until you have enough loaded.
Sep 04, 2009 | Garden
How can I open the spool for line replacement? Please help
Just push the bottom of the weed wacker in and turn to the left the spool should fall out if u need anymore answers just ask
Cheers
Johnthetr870
May 15, 2009 | Garden
Replace pull cord on ryobi model cs30 weed wacker
Good fix, mrfixit-jerr! Also, if you remove the rear cover (4 screws) you can stabilize the crankshaft by inserting a screwdriver between the lobe of the shaft and the counterweight.
Apr 03, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Black and decker 110 volt grasshog
The last time I used the weed wacker it kept stopping-almost like a short. The battery is fully charged and has a lot of power when working. Would the problem be in the handle and can that be taken apart to see if there is a loose wire?
Aug 06, 2008 | Black & Decker String Trimmer Cordless 12"...
Electrical Supplies Logo
327 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
