Question about GE 25GT539 25" TV
RCA 25" Model #F25652BL
The TV won't program channels 14, 16, 17 or anything after 33. When we autoprogram it, it shows the channels as stored, but still they don't work. All channels after 33 were Family Channel! We don't have a manual, so can't trouble shoot on our own. Please help!
  • saltismom Nov 24, 2008
    I have the same t.v. (but 27") doing the same thing, it's so frustrating! Even after calling RCA , I could'nt get my "erased" channels, (the t.v. was given to me) to store.
3 Suggested Answers
  • 23 Answers
SOURCE: GE 20GT320 TV
don't use auto programme.
use manual or semi auto.
you have to press the auto programme button a few times.
Posted on Jul 13, 2008
ltfrc
  • 227 Answers
SOURCE: get channel 3 on tv with autoprogramming
When you select channels, the one that comes in the channel number will be green and if you manually select 03 it will probably be red. Hit menu and add channel 03
Posted on Jan 16, 2009
Autoprograming wont program my numbers it keep easing all the channels
The main system control memory IC is faulty. Replace it.
Sep 24, 2013 | RCA F25254GY 25" TV
I recently bought an Xbox 360 and plugged it into the back of my TV. However, the TV refuses to show anything from the Xbox 360. I tried Autoprogramming it, and it erased all of my channels except for 1,...
MOST of their older sets are set up where the AV inputs are channels 90-93 ; if you had no signal other than the game the set will skip all those channels out.
If you have a working remote for it direct enter 90-93 one at a time .
Nothing hooked to cable fitting means set will see no signal and skip them out when auto program is engaged.
SD TECH
Sep 23, 2011 | RCA F25254GY 25" TV
Why does my RCA f32632sb not receive all channels available? Other tv is fine. this one is an older model(free off of craigslist) and it won't get a bunch of channels. I have cable 2-57 in BC Canada. ANY...
I have a old RCA tv model F32632SB...and im having problems autoprogramming it...when I start the autopramming it starts on channel 14...after its done goingthru all the channels still no picture on all channels except channel 11...ive autoprogrammed the tv 50 million times still nothing... I tried the cable cord in another old tv and the cable is fine..anybody know ????
Nov 28, 2010 | Televison & Video
The tv is showing a double image and I cannot get the color right! Model number 50v500
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You need to upgrade to the high definition cable box---but first try this. Hook the cable from the wall directly to the tv and autoprogram it. If Comcast is anything like charter they transmit the local Hd channels in a format that digital tuner will pick them up. Just channel up/down and check out the channels with -1 and -2's behind them. Depending on where you are----your local channels will usually show up wherever they normally do but with a -1 behind it.
EX: local Fox channel on 47---autoprogram and check 47-1
If this is enough HD for you then get a two way spitter and hook your box back up and keep using the RCA (composite) cables for the best it can produce.
hope this will help..
May 21, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
RCA TV E09397AB How to set to channel 3 or 4
I would suggest to unplug the TV from the power source for a while. Before plugging the TV to the power source, connect the VCR and play a movie or have some signal for the TV to store channel 3 into the memory. You might have to do the autoprogramming if the above did not work.
Let me know if you need further assistance.
Feb 15, 2010 | Televison & Video
When you are using a FullHD upscaling model. I still have to a HD setbox
the set top box is required by your cable company.
if you plug cable directly into the TV and run an auto program from the TV menu it will find most channels. BUT it will not locate them correctly.
for instance I have comcast. Channel 58 is FX but WITHOUT a cable box it shows up as the following on my HDtv's
sharp 52" shows up as channel 83.10
RCA 27" shows up as 86.6
RCA 32" shows up as 89.3
its a pain in the ****. We rent 2hd boxes from comcast at 7.99 a month and I refuse to pay them any more per month.
Contrary to what most cable providers say you WILL pick up most channels and in fact you will pick up some HD channels without the box but you have to look for them and they won't be on the same channel on every TV.
Lastly cable companies also remodulaet their signals every once and a while so there will come a time when you will have to do the whole setup, autoprogram (ch scan) again and yes the channels will once again move to another channel.
cable sucks Comcast REALLY sucks
Jan 22, 2010 | Electronics - Others
HI MY PHILIPS 25INCH TUBE T.V ONLY GOES FROM CHANNELS 2 TO 42
Either press menu on the Philips remote and go to autoprogram, or (if you have lost the remote), press volume - and channel - at the same time. When menu appears, use channel - to select autoprogram and volume - to select it.
-Tha Mp3 Doctor
Dec 31, 2008 | Philips TS2546C 25" TV
GE 20GT320 TV
Jul 12, 2008 | GE 25GT270 TV
Rca 25" f27227e
when you bring the menu up on the screen one of the items will let you select cable; another item will let the set autoprogram, let it run through all the channels and it will select what channels you should receive-then you can do channel up/down.
May 08, 2008 | RCA F25432 25" TV
Can't View Cable RCA f32444
You will have to go in the menu and switch it to cable mode, then do an autoprogram and you will have all the channels.
Sep 04, 2007 | RCA F32444 32" TV
Televison & Video Logo
192 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
