Harman kardon avr320
Lost audio to right front speaker swaped speakers swaped wire still no sound what is wrong in side reciver
  • Anonymous Mar 23, 2009
    I don't get sound output from one of the surround speakers. I swapped the cables and the speaker and checked; there's no sound. Tried the speakers 'test' option on the receiver; one of the surround speakers failed the test while the other speakers were ok.
  • 56 Answers
Output transister blown
Posted on Aug 12, 2008
I have lost all sound from my left front speaker on my AVR 135 They are Bose spreakers The system is 13 years old. Is it woorth fixing?
anything that works well is always worth investigating for a repair
it could be a simple fuse for that side amplifier, loose , broken speaker wire
have it checked out and then decide if it is worth repairing
Sep 25, 2016 | Harmon Kardon Harman/kardon Avr 130 5.1...
Wont turn on
tuner setting might be default only in stereo only. do you have passive or active speakers?
Apr 10, 2014 | Harman Kardon AVR 240 Receiver
No Memory Stotred in Harman Kardon AVR 65
You have a memory cap ,usally located on the front display,that is most likely defective.measure voltage on cap with unit off should measure at least 3-5 volts
Apr 10, 2010 | Harman Kardon AVR 35 Receiver
I have a Harmon Kardon-AVR 320, DVD 25, PA 2000. I can't get any sound with when trying to watch a DVD. I've tried every setting on each system. The L and R speaker light blink on the DVD setting. The...
We have this same problem We had friend visiting; he pushed a button and we've lost sound but only on the dvd. I've tried every setting I can think of, but can't get sound. Did you find a solution?
Dec 27, 2009 | Harman Kardon AVR 320 Receiver
Harman kardon AVR147
Make sure all the connection is in the right place,from the speaker to the unit .Try to inspect the wiring.take out the wire of the speaker one by one,check it's continuity of the wire that's not break or cut.If all of this you do allready nothing happens,the problem is inside,in the Audio section there be a big IC there.Reheat that the solder of that IC make sure when reheathing cannot be shorted.Then switch on.
Jun 13, 2008 | Harman Kardon AVR 100
Harman kardon just went dead
You may have overloaded it. Let it rest and cool down. Check the resistance on the speaker to make sure it is in spec with your amp.
Make sure someone didn't accidentally mute it or bump the audio in source wiring.
Make sure your speaker choice (A or B or both or none for headphones only) is correct.
Apr 03, 2008 | Harman Kardon AVR 225 Receiver
AVR 7000 audio/video receiver
Harman kardon amplifire are known for that.specially AVR 7000
but sometimes this comes from poor wiring and using a wire that will not conduct better sound. Remember your wiring is very important.you may think your wiring is currect, better to double check. even if your connection is ok and the wire you are using are not better to produce quality sound you will not get sound from every speaker.
good luck
Feb 28, 2008 | Harman Kardon AVR 7000
NO surround sound coming from our harmon/kardon speakers when set up to our onkyo tx-sr601 receiver. wires connected in correct areas, front left, right and center speakers work, subwoofer works. setup for...
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Jun 04, 2006 | Onkyo TX-SR601 Receiver
56 people viewed this question
 Grubhead
Grubhead
