Question about PfaFF Creative 7570
Bobbin tension Your answer did not help since it does not list Pfaff 7570.
  • ring_j May 11, 2010
    Hello, I am now retired and have time to play with my Pfaff 6122 Festival 135. Experimenting with decorative stiches, applique etc. I did not get very far since the bottom thread is very loose and bunching up. I am using Gutterman metallic thread and a single needle. Haven't tried the double needle yet.
    Any suggestions would be appreciated.
    Thanks, Judy
  • 19,396 Answers
Check also this links, hope they can help you:
Pfaff 1475 7570 7560 FAQ
threading a pfaff creative 7570
Posted on Aug 14, 2008
  • Ginko
    Ginko Aug 15, 2008
    Pfaff 7570 thread was in both links posted above. We use inappropriate on solutions that are out of contest or abusive. If you want to refuse may solution you should use thank you for trying (yellow), not inappropriate.
    I will be grateful if you can change the vote given.
    Many thanks.
I need to access the tension plates on my Pfaff creative 7570
To access the tension disks, remove the top of the machine as follows: 1. With the carrying handle raised, remove the cover (the piece that has all the stitches pictured). 2. Unscrew 2 screws completely; one is in the depression where the thread spool goes and the other is right behind the bobbin winder. 3. pull straight up. You may have to jiggle it a bit. 4. you should be able to see the tension disks from here.
Apr 16, 2014 | PfaFF Creative 7570
The tension is to tight on my bobbin
Hai. Tension is to tight on your bobbin? If yes, First you change the bobbin case. Because when you stitch is not properly and not finishing.
Apr 15, 2014 | PfaFF Creative 7570
I need to know how to reset the bottom tension. Mine is loose. I don't have my manual with me - HELP= it is a 7570
A good way to set bobbin tension.
Thread bobbin.
Hold bobbin buy the thread.
You should be able to hold the bobbin up buy the "pig tail" thread and the bobbin should not fall to the ground.
You should be able to give it a good shake and it drop about 2-4 inces.
Are you having looping on the underside of the fabric, if so this will not fix this problem.
If that is the case let me know and ill post a exp for how to fix that.
hope this helps
Mar 30, 2011 | PfaFF Creative 7570
I have a 7570 and cannot get the tension the bottom thread is loose and can be pulled right thru I checked the top and adjusted the bottom and nothing seems to change.
When you thread your bobbin in the bobbin case, hold it only by the thread. If the bobbin and bobbin case fall, the tension is too loose. If this is the case, turn the bobbin tension screw 1/4 turn until the bobbin and bobbin case do not fall when only holding by the thread. The top tension should be set between 4 and 5. The best way to see which one needs to be adjusted is to do a zigzag. If the thread is pulling more on top and your top tension is set between 4 and 5, the bobbin tension is too loose. If your top tension is set between 4 and 5 and it's pulling on the bottom, the bottom is too tight.
Feb 17, 2010 | PfaFF Creative 7570
My Pfaff sewing machine has started to loop the top thread underneath. Tried fixing the tension on the bobbin thread as they state in the manual, but the problem still persists. Any suggestions?
If the thread is looping underneath, you're top tension may be too loose or the thread may not be in the take-up lever. If it's looping on top, double check that the thread is in the bobbin tension or that the bobbin tension isn't too loose.
Oct 02, 2009 | PfaFF Creative 7570
Bobbin thread getting all nested underneath fabric
I have found that either the bobbin is not threaded correctly or the top is not threaded correctly. Try re-threading your machine. I always sew on a test piece before sewing on my project.
Apr 03, 2009 | PfaFF Creative 7570
Thread or bobbin tension
Thread tension. Beware of adjusting the bobbin screw. Pfaffs maintain their tensions just fine without adjusting the bobbin tension, unless you're using some crazy thick or fine thread. If you must change your bobbin tension, you would be well-advised to buy an extra bobbin case, because re-calibrating your tensions after changing them can be less than fun.
Increase your top tension, and your looping should cease. I normally keep my tension around 4.5. Also make sure you're using a good quality thread, and that there's nothing in the upper tension assemblies. Sometimes a tiny piece of debris can keep the top tension from applying enough tension, so turning the machine off and blowing some canned air in there can help as well.
Good luck,
Mar 10, 2009 | PfaFF Creative 7570
PLEASE HELP!!! Pfaff creative 7570 tension problems
Check your bobbin tension also. Embroidery bobbin thread is finer than sewing thread and you may need to make adjustment on the bobbing case by turning the small screw slightly. The type of stabilizer can affect your embroidery. An excellent reference for machine embroidery is Embroidery Machine Essentials by Jeanine Twigg, available on Amazon.
May 19, 2008 | PfaFF Creative 7570
Sewing Machines Logo
387 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
