Question about Brother EM-530 Typewriter
Margins how do I change the right margin?
  • 328 Answers
Most electronic typewriters work the same way to change margin settings. You use the space bar to move to the desired location then press the right margin key. You should hear a beep. If you need to set it farther to the right of the current position, then use the space bar to move the carrier to the current position, once it stops moving then press margin release then space to the new position then press right margin key.
Posted on Aug 12, 2008
How to reset the margins on Brother EM-530
On most electronic typewriters you change the margins by pressing the code button and holding down the press r margin or l margin on the key board. You want the carrier to be where you want the margin set. To set margins beyond the right or left margin move the carrier to the margin and press margin release to go past the margin. Then press code left or right margin.
Jun 30, 2014 | Brother EM-530 Typewriter
How do I release the right margin on the typewriter?
Look above the 3 key, you will see M REL that stands for Margin RELease. Move to the margin you want to change and wail holding the ALT key and press 3. Repossition the print head by using the BACKSPACE or SPACE BAR then again hold ALT as you select the new Left Margin or Right Margin (4=L MAR or 5=R MAR)
Nov 10, 2011 | Brother ML-300 Typewriter
Windows driver
.Normal{margin:0.0pt;margin-top:0.0pt;margin-bottom:0.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Times New Roman";font-size:10.0pt;color:Black;font-weight:normal;}H1{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:18.0pt;color:Black;font-weight:bold;}H2{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:16.0pt;color:Black;font-weight:bold;}H3{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:14.0pt;color:Black;font-weight:bold;} .Normal{margin:0.0pt;margin-top:0.0pt;margin-bottom:0.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Times New Roman";font-size:10.0pt;color:Black;font-weight:normal;}H1{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:18.0pt;color:Black;font-weight:bold;}H2{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:16.0pt;color:Black;font-weight:bold;}H3{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:14.0pt;color:Black;font-weight:bold;}
The entire installation cd here: http://d01.megashares.com/index.php?d01=6b830bb. It‘s an image file that you‘ll have to burn to a cd. You can use a Nero, Imgburn, Roxio, or any program that will burn aniso image to a blank cd. Burn the cd, install the driver, and then start using your webcam!
Apr 03, 2010 | Radio Shack VGA PC Camera Webcam
Changing margins
To change or reset margins, the keys involved are the ALT key to the left of the spacebar, the #keys 3,4, & 5.
The ALT & '3' keys are used to bypass the set margins.
To bypass the left margin, move the carrier to the left margin. Press the ALT & '3' keys at the same time. Release them then backspace the carrier to the point the new margin is wanted. Press the ALT and '4' keys at the same time to set the new left margin.
To bypass the right margin, move the carrier to the right margin. Press the ALT & '3' keys at the same time. Release them and spacebar to the point where the new right margin is wanted. Press the ALT & '5' keys to set the new right margin.
The main thing to remember is to move the carrier to the point where the new margin is needed. ALT + 3 bypasses old margins, ALT + 4 sets the left margin, & ALT + 5 sets the right margin.
Feb 24, 2010 | Brother SX-4000 Typewriter
Can't change the right margin
You must first position the carrier to where you would like the margin to be set, so if you want the margin to the right of where it already exists you must to the the margin and Depless the margin release function (M rel). If the typewriter is in line-by-line mode you may have to select the TYPE mode , before you do this. When the carrier is position to the place you want depress the R margin set function (CODE plus M left)
Nov 25, 2009 | Brother EM-530 Typewriter
How to change the pitch?
Here ya go...
Margins and Tabs
Margins and tabs for both Type Mode and Mem Mode are set in Type
Mode, but can be changed in Mem Mode when text is recalled for
editing. Margins and tabs are set using the typing scale which appears
on the display in Type Mode. A blinking cursor indicates the typing
position. The letter “L” indicates your left margin setting. The letter “R”
indicates your right margin setting.
NOTE: In Mem Mode, the margins and tabs used when the text
is created will be saved with the text and recalled with it,
even if they have been changed.
Margins
In Type Mode, to signal that you are near the right margin, the
typewriter will beep 5 spaces before the margin. In Mem Mode, the text
will wrap automatically when you print.
Margins are preset depending on the pitch setting, which is the number
of characters per inch. They are:
10 Pitch 12 Pitch 15 Pitch
(Pica) (Elite) (Micro)
Left Margin 12 14 18
Right Margin 72 86 108
New margin settings remain until changed again.
1. Move the Mode Selector to Type. A typing scale appears on
the display.
2. Move the cursor using the Spacebar or Back Space to the desired left
margin setting on the scale.
3. Press Margin.
4. Move the cursor using the Spacebar to the desired right margin
setting on the typing scale.
5. Press Code + Margin. A beep confirms each new margin setting.
6. You can change to Mem Mode, if desired.
Take care,
Duane ONeil
www.fjaproducts.com
800-982-9989
Jun 02, 2009 | Office Equipment & Supplies
Resetting the margins on a manual typewriter.
I can't be for sure if these are auto set margins, but it sounds like they might be. If they are, first move the carriage as far to the right as you can. Hold the Left Margin Set (not Margin Release) lever as you move the carriage all the way to the left. Release the Margin Set Button or Lever. Now hold the Right Margin Set Button or Lever (not the Margin Release), and move the carriage all the way to the right while holding the Margin Set. Once the carriage is all the way to the right, release the Margin Set. Move the carriage to the place you want to set your left margin. Hit the Left Margin Set and then release. Move the carriage to where you want to set the right margin. Hit the Right Margin Set and release it. It gets confusing, but Margin Release does not set margins. Its sole purpose is only to bypass the margins. Hope this helps.
Feb 19, 2009 | Royal MS 25 Typewriter
Swintec 2000 Margin
You should reset the margins where you would like them. To do this, go the the file screen and press MARGIN. Press <--- to change the left margin, or ---> to change the right margin, or the up arrow to change the top margin, or the down arrow to change the bottom margin.
Do one at a time. When you choose one (i.e. <---), the message "LEFT MARGIN SETTING" appears on the screen and the cursor moves to the left margin column automatically. Move the cursor to the desired location by using the arrow keys. As you move the cursor, the corresponding margin mark moves along with it. The press "DO" to set the new margin.
Hope this helps.
Jay @ www.granadahillsbusinessmachines.com
Aug 26, 2008 | Swintec 7040 Typewriter
Brother EM-530 Typewriter Logo
257 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
