Question about Paragon 1911-8 Popcorn Maker
Sealed pot lid
Hi!
I was cooking a stew for a couple of hours on low heat. When it was done, I turned the stove off and went to do something else. The lid on the pot is now sealed (this is not a pressure cooker)! I cannot get the lid off and don't know what to do! This is a large, wide cuisinart stainless steel cooking pot.
    President:
  • 1,489 Answers
Heat the pot again -- the positive pressure inside will break the seal and allow the lid to come off.
Posted on Apr 22, 2009
    New Friend:
Sam is correct. The cookware you are using is made for steaming rather than boiling method of cooking. when you turn off the heat the steam condenses back into water which creates a vacuum, because the water takes up less room than the steam. This is the same process that happens when canning fruits or vegetables.
when you turn the heat back on you create the positive pressure in the pot and the lid can be easily opened again.
Posted on Feb 02, 2015
6ya staff
SOURCE:
Stew was supposed to cook for one hour. Not close to done. Still on but no idea how long it will take. Was set to slow cook as recipe said.
When you use a slow cooker, you must either boil the food before adding it to the slow cooker or add an hour to the cooking time to bring it up to a simmer. That is the time that the cooking actually starts to make the meat tender. Stewing beef would take at least 2.5 to 3 hours. The only way you would do it in an hour is you used fillet steak.
Feb 07, 2016 | Crock Pots & Slow Cookers
Where can i find a manual for ultrex pressure cooker?
The company had a major recall and went out of business. No manuals appear to be available on the web.
Here are some general instructions you can use:
1 Set up your cooker. Place your Ultrex Pressure Cooker on the stove. Remove the lid and pour in no more than 2 inches of water. Depending on what you are cooking the amount of water will vary. More water will ultimately cook larger amounts of food, but you will need to refer to your specific model's instructions on this matter.
  • 2 Put in the food you wish to cook. Close and lock the lid firm to the pot. Make sure it is locked securely so none of contents boil out of the top.
  • 3 Turn on your burner to high heat for approximately ten minutes. Allow the water to boil.
  • 4 Turn the stove down to a low setting after the water is boiling in the cooker. Flip the pressure valve closed and allow your food to simmer.
  • Set the pressure valve to ten pounds. For vegetables, cook 30 to 45 minutes. For meats, cook 45 to 60 minutes.5
  • 6 Open the pressure valve and allow the pressure to discharge. Unlock and remove the lid to find your fully cooked meal.
  • Aug 25, 2014 | Ultrex Crock Pots & Slow Cookers
    What is the difference between a stew and a casserole?
    A stew is cooked on a stove or over a fire and a casserole is cooked evenly in an oven. As well, casseroles are cooked either covered or not, while stews are usually covered so they don't evaporate.
    Jan 14, 2013 | Home
    The clock on the stove was flashing and now I can't get time set and the oven buttons don't work to put on broiler or oven. I don't know how this happened or how to correct it
    hello,
    You can set the timer on a range slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking. The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a range slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
    Fill the insert of the range slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
    Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
    Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
    thanks for using fixya
    Aug 18, 2010 | Tappan TGF657 Gas Kitchen Range
    Do you use water in a slow cooker
    Yes you do.
    It will not be like a pan on the stove although, because a crock pot does not lose as much moisture because it has a better seal. So For example
    Stew from a can already has enough moisture in it, so no water.
    A meat roast will want about an inch of water or a can of soup. A crock pot uses lower heat than a stove plus moisture (like steam) to cook.
    Enjoy the slow cooking adventure !!!!!!!!!!!!!!!!!
    Mar 13, 2010 | Crock Pots & Slow Cookers
    Whats the differences with the low high and auto settings on a slow cooker which setting is considered best for cooking stews
    The difference is the time and how warm it cooks. Low cooks a slow, lower heat - cooks 6-8 hours. And High is a faster cook at 4-6 hours. I tend to use low for stews and chilis.
    Feb 11, 2010 | Crock Pots & Slow Cookers
    Need directions for Comet stove top rice cooker
    Fill the bottom to the line with water. Put two cups of rice in the top and two cups of water. Put on stove top on high until lower water is boiling, turn to medium heat. For white rice check after about 20 minutes, if water is assorbed and rice is tender, fluff with a fork...eat. If it needs a few more minutes of cooking, no problem.
    Brown rice will take about 45 minutes.
    I have used my stove top cooker for at least 35 years...ordered it with box top and some money from Comet Rice.
    Pat
    Mar 09, 2009 | Kitchen Appliances - Others
    Why does my crock pot cook at too high a heat?
    With something that small, there is not a lot of resources for parts and repair. The item is considered a throw away. You could contact customer service at RIVAL and see what they say about the issue. Could be mis-wired or something like that. The only easily replaced part for that is the stoneware.
    Jun 16, 2017 | Rival Crock Pots & Slow Cookers
    Crock pot use
    You should keep the lid on as much as possible. You are correct; once you open the lid, the liquid inside can quickly lose temperature at a rate of 10-15 degrees per minute.
    Additionally, taking the top off allows steam to escape, which reduces the point of cooking in a slow cooker (cooking in a relatively closed system, with the steam condensing back to water and flowing back into the broth).
    It's not doing a whole lot to the flavor (aside from causing the stew to thicken with the loss of water), but it is definitely causing the cooking to take longer than it should.
    Nov 02, 2007 | Rival 38601 Smart Pot 6-Quart
    Rice cooker vs a crocpot/slow cooker
    I have both and use both for different things. The rice cooker cooks faster than the slow cooker. What the Crockpot does really well, the rice cooker cannot do. For example, with the crock pot, you can buy less expensive cuts of meat and because of the slow cook method, they will be tender, juicy, and delicious. You can make soups, stews and casseroles in a crock pot and the great thing is that you can turn it on low, go to work, and when you come home, dinner is done. You can cook the same types of things in a rice cooker but you can't leave it all day. You CAN saute', fry, etc,. in your rice cooker which you can't do in a crock pot but for dense veggies and tougher cuts of meat, stew beef for example, there's no comparison. I have an Oster Rice Cooker and Steamer which I use nearly every day. I cook rice, obviously, casseroles, veggies, spaghetti and meatballs, all kinds of side dishes and soups in it. I use the crockpot several times a week but more often in the Fall and Winter when I make soups, stews, chilis, roasts and BBQ. Oh my gosh, you have to try BBQ Ribs in the crock pot! They melt in your mouth. Go to Yahoo! Groups. You'll find all kinds of great info for both your rice cooker and crock pot. I have one of the fancier, more expensive crock pots because I take it to work with me one day a week for lunch. The lid seals and it comes with a carrier. If you do most of your cooking at home, you can spend a little less and get a good one. I recommend getting one that has at least 3 heat settings though. Different foods require different temps. Happy Cooking!
    Nov 01, 2007 | Town Food Service 57155 55-Cup Rice Cooker
    Paragon 1911-8 Popcorn Maker Logo
    913 people viewed this question
    Top Paragon Kitchen Appliances - Others Experts
    Marks concession...
    Marks concession...
    Kami
    Are you a Paragon Kitchen Appliances - Other Expert? Answer questions, earn points and help others
