Question about Sony NW-E507 MP3 Player
End has come off and i cant put it back togeter
My brother pulled some headphones out of the socket and the end which you twist has come off and i cant fix it because there are two small metal things which i dont know where they go
  • 8,596 Answers
You need a new set of headphones.
Posted on Sep 08, 2008
How can I fix my aspire 5349-2804 headphone port?
Power output on a headphone socket is not great - depends on the headphone and speaker resistance - have you tried a cheap pair of in ear headphones to see if it is the headphone socket.
Headphone socket does sometimes break like the power socket its one of the most common problems on a laptop.
If so its not difficult to find a new headphone socket or even re-solder the old one - it may be a dry joint!
Are you getting sound through the laptop speakers for a start.
The headphone socket should interrupt the main speakers automatically so there is no setting in sounds and devices in windows that would cause your problem.
May 12, 2014 | Acer Aspire 9300-5349 Notebook
No sound from built in speakers
Use a paper clip as a hook to pull the end of the headphone socket to the front, to contact the speakers when headphone is not plugged in. Paper clip of 1 inch size has to be straightened out. One end bent at 1 inch for a lever. The other end bend 1/16" for a hook to pull the end contact. Cut that end to a chisel to use as wedge for side contacts pull to the center. You also need a bright LED flash light to see all the parts in the socket.
Apr 07, 2012 | Dell Vostro 2510 Laptop
When I connect my earphones sennheiser to my ipod and play a song, the song sounds fuzzy and low , but if I twist it around , or move it around , when its still inside the ipod, I can get it back to...
Afraid so. The fact that your brother's earphones do the same thing points directly to the ipod. It may be just a loose connection where the wires go in. Be brave, and undo the screws you can see, so that it pulls apart. Without touching anything else, have a look where your connection goes in. It may be just loose there, and you might be able to tighten it, If not, put it all back together again, and ask a repairman how much to fix it.
Mar 24, 2011 | Jwin iLuv i301 Consumer Headphones
How do i change my rear brake light
I believe the plastic cover has either screws or clips on both sides just pry easy under pressing inward.. slowly haste makes waste with these little things... good luck bulb should pull straight out of the socket after twisting it out of the cover
Mar 05, 2011 | 1991 Toyota Celica
Where is my jack for headphone on optiplex 260 need to put headphone for skype please give best options.
if you cant find it in front, try at the back of the unit, it has a 3 socket the green one.
Dec 05, 2009 | Computers & Internet
My headphone plug has broke of in my laptop so i have no sound output what do i do ??
Hmmm..
1. You have to use a small pair of "needle nose" pliers to get that out of the jack.
2. Invest in a set of USB headphones or Bluetooth headphones while you try to get the plug out of the jack.
USB headphones ($20 ~ $50)
Hope this helps...
Sep 03, 2009 | Acer Aspire 5500 5570-2609 Laptop
How change lamp bulb on transmission indicator and speedometer
just pull off the bezel on the dash by unscrewing it and then unscrew the gauge assy.and pull it towards you enough to reach behind it and twist the rectangular light socket to the right a it should come out, replace the bulb and put it back in by twisting to the left, then put everything back together in reverse order. it takes bulb size 194. good luck
Jul 14, 2009 | 1989 Chevrolet G20
Head light
Get under the car reach behind the bumper reach towards the blinker then find the wire that goes to it. Then twist the end left and pull out the light bulb in and and replace. For the headlight blinker you have to unscrew the headlight with either a 10 or 13mm socket...pull it out...then twist the end that goes into the blinker left...replace bulb....put things back together....done.
Dec 31, 2008 | 1999 Chevrolet Lumina
Connecting to speakers
The socket on your player is an audio output. The headphone socket on a Hi-Fi unit is, again, an audio output. If your cable has a 3.5mm audio mini-jack (male) at each end, you can connect the headphone output of your device to an input socket, but these generally only exist in some in-car players, and rarely on home audio products.
If you want to connect to a Hi-Fi system, you are better off connecting to the phono-in sockets that you will find at the back of your unit, notably on dedicated amplifiers. You can then get a simple lead with a 3.5mm audio mini-jack (male) at one end and a pair of phono plugs (left and right) at the other end. This should cost no more than a few pounds and are available from places like Maplin or from specialist sellers on eBay.
Nov 13, 2008 | Philips GoGear SA3125/37 MP3 Player
How to change the brake lamp
With the rear hatch open you should see to black plastic plugs hiding the access screws, once those are removed swing the whole assembly out 4 to 6 inches. The only thing holding the other end is two posts on the light assembly go into two rubber sockets. Pull straight out from the vehicle and it will be removed.
Jun 15, 2008 | 2006 Pontiac Torrent
Sony NW-E507 MP3 Player Logo
20 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
