MOUSE MY MOUSE GOES ANOTHER WAY THAN WHAT I WANT IT TO. AND IT ALSO MOVES SLOW. SOMEONE SUGGEST THAT IT WAS THE BALL, SO I CLEANED IT WITH ALCOHOL. BUT I AM STILL HAVING THIS PROBLEM. PLEASE HELP BECAUSE OF THIS I CAN'T ENJOY MY COMPUTOR.
  • gigatt197820 Aug 23, 2008
    thanks for the info, it work for a few days than it happen again. so i went to buy a new one. you were very helpful. it is good to know that there are people out there 2 help when u need it.
  • 981 Answers
If the motion is completely inverted, look around for some unknown utility (e.g. using AnVir Task Manager Free ) that's doing this unliked job for you.  If it's just kind of not moving right, take out the ball and clean the -rollers- the ball goes up against which are exposed by removing the ball...use a fingernail or nail file or something to get it back to being a smooth rod, or buy an optical mouse already!  Mice can eventually go bad because the IR emitters and receivers inside get jammed with dust; so if it's moving only 1 pixel at a time if at all, you can carefully clean it out with compressed air.  The electronics can go bad, too, oddly enough.  So it's possible you need a new one.
Posted on Aug 13, 2008
Mouse with its own mind
If the mouse has a ball, it probably needs cleaned along with the wheels inside behind the ball. Always do all maintanance with the mouse unplugged from the computer. You can see them when you take the ball out. Typicaly, you twist the cap holding the ball in and it just falls out. At this point, you can clean the ball with a mild cleaner and the wheels inside the mouse with a pencil eraser, pocket knife or a Q-tip with rubbing alcohol.
If it's an optical mouse (red or blue laser under the mouse) simply clean where the laser light is. If this does not work, then plug the mouse into another USB port. If that does not work, then restart the computer properly (not hard or soft reset). That should fix it. If not then the mouse probably is bad.
Mar 14, 2015 | Computers & Internet
Can I fix the roller in my wireless mouse?
Open the mouse. (Slide the panel on the bottom that surrounds the ball, and pull the ball out. Clean the ball and the rollers inside the mouse with rubbing alcohol. Remove all debris, hair, lint, etc.
Voila!
Sep 26, 2014 | Computers & Internet
My mouse pad will not move my cursor on my computer
If your mouse is the older ball type hold the mouse level about 12 inches off the pad and move the ball on the underside of the mouse with your finger. If the cursor moves you may need to simply clean any dust from inside the device and clean the ball. Open the open to release the ball. Theres a round plate on the underside around the ball. Turn it to the open position a remove the ball. Clean any dust from inside with canned air or a soft brush. Clean the ball with a small amount of alcohol and let dry completely. Replace ball and plate and you should be ready to go.
If you have an infrared mouse, your mousepad may be too glossy. Dry a pad with a dull finish.
Jan 18, 2010 | Computers & Internet
Rollerball on Wireless mouse keeps getting gummed up. Cleaning done frequently but need to open mouse to get inside cleaned ?
The Apple wireless mice aren't made to be disassembled, not even by techs. If you disassemble it to clean it, you must glue it back together.
The best way to clean the rollerball is to remove the batteries and roll the ball upside down on a cloth soaked in alcohol. Be sure to roll the ball alternately depressed and not depressed for the best cleaning, and roll it in all directions.
When this no longer works, you can either attempt to clean the ball yourself at your own risk, or purchase a new mouse.
Nov 25, 2009 | Apple Computers & Internet
Poor mouse movement
If you remove the ball, look inside there are 2 white rollers(they may ba a different color) that touch the ball as it moves, there will be build up of gunk on them from the ball, use an exacto knife or something small to scrape the stuff off of them.
Apr 16, 2009 | Computers & Internet
Mouse only moves up and down not side to side
If it is a PS/2 mouse with roller ball, the horizontal wheel sensors are gone. No sense in trying to fix this roller ball PS/2 mice are really cheap. As far as the USB mouse you may have to install a driver. Depends on the operating system.
Mar 02, 2009 | IBM NetVista M41 PC Desktop
Scroll ball not going going down
I had the same problem and checked at the Apple store and was told to rub the scrolling ball with a alcohol prep pad. works wonderful. May have to repeat as needed.
Feb 21, 2009 | Apple Mighty Mouse Wired
Poor tracking in trackball
Sounds like it needs clesnong. dust and dirt get inside through the ball and should be cleaned ever so often.
Hope this helps. Bud
Jan 08, 2009 | Kensington 64213 Expert Mouse Pro
Apple wireless mighty mouse
Here is my solution.
<embed src="http://www.veoh.com/videodetails2.swf?permalinkId=v378809PrA5a3pg&id=1377316&player=videodetailsembedded&videoAutoPlay=0" allowFullScreen="true" width="540" height="438" bgcolor="#000000" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer"></embed><br/><a href="http://www.veoh.com/">Online Videos by Veoh.com</a>
Nov 16, 2007 | Apple Mighty MA086LL/A Mouse
Computers & Internet Logo
315 people viewed this question
David Payne
David Payne
