Question about Whirlpool LER5636P Electric Dryer
Whirlpool dryer Runs for a few minutes then stops. Will start again after cooling down
  • 1 more comment
  • Anonymous Aug 29, 2008
    Whirpool dry le5720xsno runs a while then cuts off, will start after a few minutes, motor sound rough
  • stinky70 Nov 14, 2008
    I have the same problem with a Kenmore. It will run for about 10 minutes and then shuts off, and won't start again until it cools down. I had a guy look at it, he said it was a problem with the venting system, not my dryer. He disconnected it from the venting system, ran a shorter piece of hose and did not hook it back up to the vent and it still is not working. I called him back and over the phone he told me it is the motor. I'm not sure I believe him. What else could it be? Thermostat or something?
  • Anonymous Mar 27, 2014
    Runs and stops
  • 30 Answers
If your dryer stops during its cycle, wait ten minutes and start dryer again. If dryer starts, then the motor was overheating.
Solution, Check for lint blockage around the motor and for possible overloading. If dryer repeatedly stops during its cycle, especially during consecutive loads, replace motor.
Good luck
Posted on Aug 11, 2008
2 Suggested Answers
protek480
  • 1714 Answers
SOURCE: Dryer runs when first started, quits halway through drying cycle.
High temp. limit is probably at fault and will need to be changed.
Posted on Jul 13, 2009
I have a DV42H5400 dryer less than a year old that runs for a few seconds than stops. No error code but the cooling light flashes. After a few minutes it repeats the process.
Clothes Dryer Stops and Starts ' HomeTips
www.hometips.com/repair-fix/clothes-dryer-stops-and-starts.html
Apr 23, 2015 - The dryer's heating element works and the motor runs smoothly, But it... and then running the dryer with nothing inside for a few minutes-if it ...
Sep 26, 2015 | Dryers
AMANA gas dryer runs only a few minutes then stops
Sounds like your motor is weak after its cools down does it start again then the same thing happens?
May 01, 2014 | Amana ALG331RAW Gas Dryer
Whirlpool LER7646JQO Electric Dryer turns on, drum turning, runs for 3 to 5 minutes then clicks and shuts off. Smells like it is burning. No kink in hose vent or lint clogs.
Most dryers have more than one thermostat.
Most likely, the operating thermostat has failed, but the high limit thermostat is working and turns off the machine when it gets too hot. When it cools down it will start again and run briefly. If the high limit thermostat fails, the thermal fuse will permanently stop the dryer to prevent a fire.
Apr 07, 2010 | Whirlpool Dryers
Electric dryer keeps stopping
Most likely, the operating thermostat has failed, and the high limit thermostat turns off the dryer when it gets too hot. When it cools down, it will start again.
Apr 06, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer stops drying on its own.
it sounds like its overheating. there may be lint in the vent hose or even stuck in the machine before getting to the lint trap.
Aug 17, 2009 | Whirlpool LER4634J Electric Dryer
Dryer heat shuts off
Hello, reading between the lines I'm going to assume you have a gas dryer. This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Jul 24, 2009 | Whirlpool Dryers
Jul 13, 2009 | Whirlpool Dryers
Dryer runs for 20 minutes. shuts down. won't start again for 2 hours.
Hi, It sounds like you have a motor going bad. If this is a whirlpool brand models, the motor is about $90.00 to $100.00. If I can assist you further, please let me know.
Thanks
Vic
May 21, 2009 | Dryers
62802 stops running after a few minutes
It sounds as if you have a defective drive motor.  After the motor runs for a while and heats up, the internal thermal switch cuts it off before it gets too hot and becomes a hazard.  Once the motor cools down and the thermal switch makes up again, it will run and then repeat this process.
Oct 15, 2007 | Kenmore 62602 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
578 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
