Question about Sony PlayStation 2 (PS2) Console
No control controllers
My console loads and the controllers have power ,both wired and wireless but I get no input from them, what's up?
  • 709 Answers
Check to see if it will read a memory card. You probably have a bad Controller port. You can order one from Ebay, then install it if you have the original PS2. If you have the slim, you may need a new motherboard.
Posted on Aug 11, 2008
Why wont my xbox turn on it shut off mid game and the controller flashed the power ring?
Are you using a wired or wireless controller? Some after market wired controllers have been known to cause this same effect. The problem is the usb port. What a lot of people don't know, is that it is possible to input anything usb either up, or down. But beware! If you connect something the wrong way, it could fry it, because it is sending power through it. The easy way to tell, is looking at the plug. It should have "DOTS" that tell you up or down. Make sure these dots are facing up when you install into the usb port.
Jul 23, 2014 | Microsoft Xbox 360 Console
Controller doesnt turn on but batterys are good
Connect a game controller
Solutions
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Oct 11, 2013 | Microsoft Xbox 360 Controller
My controller was working one day and then stop working the next day it had fresh battery
Solutions
Jul 31, 2013 | Microsoft Xbox 360 Controller
Ho w to fix x box from controller to x box is really slow how to make it normal
Connect a wired Xbox controller
5fb17f50-7448-45d5-a294-9ea90994f55b.png?v=1#controller-wired-m-m.png Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
cbe46bf0-3a46-4d53-9d8c-6697aa57622a.png?v=1#controller-cable-release-m-m.png The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
Feb 08, 2013 | Microsoft Xbox 360 Controller
How do i reactivate the wireless controller to my xbox 360
How to Configure an Xbox Controller Fotolia.com"> configure-xbox-controller-800x800.jpg Configure you Xbox controller.
The Xbox 360 utilizes two types of controllers: wired and wireless. Like most operations on a video game console, configuring a controller requires little effort. You can either plug the controller into a port on the Xbox 360, or sync a wireless controller using the console's built-in controls.
Difficulty:Easy Instructions
  1. Wired
    • 1 Connect the controller's cable to the in-line release cord. This cord prevents you from accidentally pulling the Xbox 360 along with your controller during game play.
    • 2 Insert the in-line release cord's USB plug into the USB port on the front of the console.
    • 3 Turn on the console to activate the controller automatically.
    Wireless
    • 1 Insert batteries in your wireless controller, if necessary.
    • 2 Hold down the "Guide" button on the controller.
    • 3 Push the Xbox 360's "Connect" button, located on the front of the console.
    • 4 Push the controller's "Connect" button to sync it with the Xbox 360.
Read more: How to Configure an Xbox Controller ' eHow.com http://www.ehow.com/how_7780486_configure-xbox-controller.html#ixzz1PRsAYmUA
here is a video on how to sync your wireless controller to your xbox360 console
http://www.youtube.com/watch?v=GpV-b1de2lM&feature=related
if you think this help please rate me sir thank you so much!!!
Jun 16, 2011 | Microsoft Xbox 360 Console
Xbox 360 controller not working, all 4 lights are blinking.
The wired and wireless controllers can be actively connected to an Xbox 360 console all at one time. Each connected controller is assigned a quadrant on the Ring of Light. Before you can connect a wireless controller, at least one quadrant must be free and will be unlit.
Connecting an Xbox 360 Wireless Controller to an Xbox 360 Console is called Connecting. To connect a controller to a console:
First, Press and hold down the Guide Button on the wireless controller until it turns on.
Second, Press and release the power button to turn the console on.
Third, Press and release the connect button on the console.
Fourth, Press and release the connect button on the controller.
Fifth, After the ring of light on the controller and console spin and flash once, the controller is connected. The quadrant that remains lit indicates the controller's position.
Four Green lights on the controller's Ring of Light flash continuously
The Please Reconnect Controller message appears on the monitor
There is interference and the controller does not respond properly
Step 1: Ensure that either the AA batteries are new or the Xbox 360 Rechargeable Battery Pack has a full charge.
Step 2: Ensure that you have performed the proper procedure to connect the Xbox 360 Wireless Controller to the console.
Step 3: If still experiencing issues, ensure there is a clear line of sight between the front of the console and the wireless controller. If there are any obstructions, especially metal objects, remove them.
Step 4: 2.4 gigahertz cordless telephones, microwave ovens, and Bluetooth headsets for cell phones can interfere with the operation of the wireless controller. Turn off or unplug those devices and then try to connect the wireless controller to the console again.
Step 5: If these steps did not resolve the issue, the wireless controller may need to be replaced.
Jun 06, 2010 | Microsoft Xbox 360 Controller
My controller just shows all four lights flashing and when i try to sync it, the lights just keep spinning round and does'nt connect
Jun 03, 2010 | Microsoft Xbox 360 Controller
Ps3 will not reconize intec in any way wireed or wireless. just invisible
CONNECTION A:
DO NOT INSERT BATTERIES INTO THE CONTROLLER; THE USB CABLE USED WILL SUPPLY THE POWER TO THE CONTROLLER.
STEPS # 1 – TURN THE POWER ON TO THE PS3 CONSOLE.
STEP # 2 – CONNECT THE USB CABLE TO YOUR PS3 CONSOLE AND CONTROLLER.
STEP # 3 – NEXT PRESSE THE SYNC BUTTON ON THE CONTROLLER, THE CONTROLLERS LED INDICATOR’S LOCATED ON THE FRONT OF THE CONTROLLER WILL START TO FLASH RAPIDLY.
STEP # 4 – CONNECT THE USB RECEIVER TO THE USB PORT ON THE PS3 CONSOLE.
STEP # 5 – WHEN THW CONTROLLERS LED INDICATOR’S LOACTED ON THE FRONT OF THE CONTROLLER START FLASHING SLOW PRESS THE HOME BUTTON.
WHEN THE CONTROLLER HAS ESTABLISHED A CONNECTION BETWEEN THE CONTROLLER AND THE USB RECEIVER ONE OF THE CONTROLLER’S LED INDICATOR’S WILL BECOME SOLID RED.
Jul 12, 2009 | Intec PlayStation 3 Turbo Shock III...
I can not connect my wireless controllers. My
hi, i had this problem and it is really annoying, but is a really easy fix, first you must turn on your console leave the controller off, hold the sync button on the console for 30 seconds then turn the console off, remove all the wires from the console and the power plug from the wall, after about 5 minutes, reconnect the wires and turn the console on then the controller, now try and sync them, if this hasnt worked im sorry try calling microsoft im sure they can help. www.xbox.com/support
Jul 10, 2009 | Microsoft Xbox 360 Console
Xbox 360 wireless controller
change your controllers m8 sounds like they faulty i have had no probs
Oct 24, 2007 | Microsoft Xbox Console
Sony PlayStation 2 (PS2) Console Logo
41 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
