Question about RCA P60920BL 60" Rear Projection Television
TV WILL NOT STOP CHANGING CHANNELS
My RCA will come on, but the channels will not stop changing. What is the problem amd can it be fixed?
  • 979 Answers
Go and "hide" the remote from the set and see if that helps. Rare, but possible is a problem with the phase-lock loop circuit in the TV, or, encoder for that remote that you just hid....accordianman
Posted on Dec 06, 2008
SOURCE:
The channels on my ge 32gt720 tv keep changing by them self
Channel change button on the remote or on the side of the TV coule be stuck.
Jul 20, 2014 | GE 32GT720 32" TV
My tv won't stop changing channels by itself
I just fixed the problem very easy... The RCA have a front cabinet which is very easy to remove. I took it out and the only thing that is expose is the speakers and the sensor control. Is a little panel about 5" just spray it with dust spray and that what I did Is not changing channels by itself anymore. I save $3,000 I was about to trash it. Im happy I did that...
Dec 05, 2009 | RCA P52926 52" Rear Projection Television
RCA model# P52937SGEO35C5O6E---PTK195M4B Home theatre guide+gold
the buttons switches are leaking more than likely this a comon problem in a lot of tvs they start leaking and send a voltage signal to the ics and tv will start doing funny things. Anyway need to replace these switches probley about six of them in all they are mounted on a board behind where you push the power button. Should replace all just to be on the safe side.
Feb 15, 2009 | RCA F32648 32" TV
Channels flipping non stop
Ether the front panel channel button is sticking or the remote channel button. take the remote out of the room.. if it still is changing channels make sure the channel buttons on the front of the set are not sticking. Spay a little WD 40 on them then wipe them off
Dec 03, 2008 | RCA F32649 32" TV
Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Oct 04, 2008 | RCA TruFlat 27F520T 27" TV
RCA F32650 TV changes channels by itself
Problem is common to RCA models. The issue is bad solder joints in the tuner area. Resolder the entire tuner section of the board and the problem will be resolved. No parts are necessary.
Aug 27, 2008 | RCA F32650 32" TV
Hi there!
I think your remote may be at fault. Liquid spill or sweat from the hand accumelates on the inside over some time and then becomes sticky. Some of the buttons may be permanently activated. Then other functions won't work. Have someone check it for you or if familiar yourself. Regards, JUS004
Mar 12, 2008 | RCA TruFlat 27F520T 27" TV
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
RCA 32" TV
The most likely problem is a stuck tact switch, if it goes up in channel number, 5, 6, 7, etc. then the channel up button is stuck, if it counts down it`s obviously the ch. down button. Problem is you have to remove the guts of the set to get at the control boards screws, you can try turning on the set and poke around the offending push button with a tooth-pick, if it stops changing channels leave it alone and use your remote from now on to change channels, if you can`t get it to stop the tact switches or the control board module will have to be swapped out, hope this helps
Nov 27, 2007 | RCA F32695BC 32" TV
Tv wont stop changing channels
ok, Sony had this issue on their early production. The problem you are having is called a leaky switch. The volume down switch on the TV is leaky. To fix this you must replace the switch. This part is called the switch block. Part number 1-473-549-21
Average cost $26
Best regards
Circuitcity
Dec 18, 2006 | Sony KV-27V42 27" TV
Televison & Video Logo
61 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
