Re: I need to know how you would replace the heating...
First you take off the top panel two screws then four qr five screws to take off console then four screws top of front panel and two scews just below your filter on front panel and you have access to your element
Overheating is almost always an airflow problem. Check airway before the place the fuse is located and the vent pipe and vent after the fuse to make sure they are open, If the airway is clear, the thermostat may be allowing the heating element to stay turned on until the dryer gets too hot,
This error means there is an issue with with the heating portion of the dryer. Could be the thermistor, or the element, or the control board. You have to use a multimeter to troubleshoot the problem. You unplug the dryer, disconnect the element and use an ohmmeter to test the element for continuity.
The element should be between 10 and 50 ohms if it's good. The thermistor should be around 10,000 ohms at room temperature and if both check good, replace the control board.
ften a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Ohm out the thermal fuse, if it is ok, then you can ohm out the heating element, be sure to visually check the element as well becqause it could just be shorted out internally giving you a reading, but first and foremost check your voltages be sure you are getting 240 across the outer plug spades and 120 volts from left to common and right to common, unplug this thing before you get into the element area or you could end up with a smokin fro !
I have the same problem--it is the heating element. Bad news is they don't make the part anymore. The solution from maytag.com is to buy a new one and they will reimburse you 15%...not a very good solution considering how much this one cost and the amount of years it has been used. If you find a place that sells the heating element please post!
