Question about Samsung Televison & Video
Tv turns itself off after 5 to 7 min's. repeats 3 or 4 times then may stay on for the rest of evening viewing. model dlp tv. sp61l6hx1x/xsa . aprox.2yrs old, only started doing this a few days ago.[ no, the timer is not set] any help would be great thank's randy
  • randy278burl Aug 11, 2008
    fuse is ok,does not loose power just shuts off, as if power button were
    pushed. returns to on pos. upon pushing power button.
    not sure, after 3 or 4 cycles of off/on tv stays on for extended
    period of 2/3 hrs. then may or maynot fail. as if it needs to warm
    up to stay on.
    Genius:
  • 2,920 Answers
Power supply is weak possibly going out rate me please
Posted on Aug 11, 2008
    Master:
  • 848 Answers
Just check the fuse .....
provide details about model number of tv
Posted on Aug 10, 2008
  • gopinath pasupathy Aug 16, 2008
    1. The main filter capacitor or other filter capacitors in the low voltage
      power supply is dried up and this can cause all kinds of regulation problems.
    2. The power supply regulator is defective (or marginal) allowing excessive
      voltage on its output and then the X-ray protection circuitry shuts you down.
Samsung DLP has no sound for about 8 minutes when first turned on.
Mine does the same thing. It makes a regular popping sound that does not change in level with the volume control. When the popping starts getting erratic the pixelated sound starts and in a short time the sound straightens out for the rest of the viewing time. However, the next time the cycle repeats itself. Did you find a fix?
Nov 24, 2010 | Samsung HLN567W 56" Rear Projection HDTV
My akai dlp tv turns itself off then it flashes
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Feb 17, 2010 | Akai LCT3201TD 32 in. LCD Television
Sony kdlf-50e2000 will only stay on for 5-1o min then the screen will go out?
If TV turns back on itself and repeat that on-off cycle then its time for new lamp in TV.
How old is this TV and when did you replace its lamp?
Sep 26, 2009 | Sony KDF-50E2000 50" HDTV
TOSHIBA dlp projection, model 42hm66 won't stay on
Could be the power supply. You can check the power from supply with multi-tester or voltmeter. If have a service manual, then I suggest testing the ballast as well
Aug 07, 2009 | Toshiba 52HM95 52" HDTV Projection...
Had a power outage while watching tv. Then 3 blinking lights.
This is an on-going problem with DLP sets. Normally you shut the set off and the cooling fan cools the lamp down and then it shuts off. In your case, of which it's not your fault, however your lamp has taken a major hit by not properly cooling down, in turn, you need to replace your lamp at this time.
I suggest in the future if you have an electrical storm and a chance of a power outage while your watching tv, I would'nt play that model or any other model of a DLP set.
Jun 23, 2009 | Samsung HL-S5087W DLP TV
Zenith 52'' dlp tv won't turn on
after an hour tv shuts off and you have to wait to turn it back on
Jun 12, 2009 | Zenith Televison & Video
Tv powers off and on after operating for about 1 hour
Same happened to me with my old panasonic set. It was a dry-joint. You can try re-soldering the circuit.
Good Luck.
P.S. - Check the Power Suply area closely.
Feb 20, 2009 | Hitachi 60VX915 Rear Projection Television
Lcd tv turns off after 5 mins, leave 2 mins comes on to stand by
Swollen ( bad ) caps in power supply first place to look.............T.
Dec 17, 2008 | Samsung DLP HL-P5663W 56" TV
Intermittent power on/off
My exact same TV did the same thing. Your fuse us going bad. Go buy a new one and replace it.
Jul 01, 2008 | Panasonic CT-32G11 32" TV
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
