Question about Frigidaire GLWS1233A Top Load Washer
Tripping gfci plug in
Washer trips gfci plug
  • buggdd Aug 10, 2008
    both checks good, even plugged into another gfci receptacle, it still tripped as soon as plugged it in and the washer was to off
  • 95 Answers
Check the plug and outlet itself.
Posted on Aug 10, 2008
  • Anonymous Aug 15, 2008
    if you are still tripping the GFI's, you have either got a unit that is drawing more power than the circuit can handle, or the power supply is need of repair
SOURCE:
Hi lg washer dryer combo trips safety switch as soon as plugged in and wall turned on
The washer tripped the breaker once and OR after the breaker was reset it ran additional loads with no problem then it tripped the breaker again.
Intermittent problems are always difficult to diagnose because the problem usually doesn't occur when you're making the checks.
If the washer ran additional loads the problem will not be an electrical short with one of the washer parts. If the lid switch had a short it wouldn't run additional loads.
if the additional loads used the same cycle as previously. A timer can have an internal short that might trip the breaker in heavy duty cycle but not the permanent press cycle.
If you have access to a clamp on amp meter, see the image below, then you can check the amp draw of the washer. The washer normally will draw about 10-15 amps at start up and about 5-8 amps while running. The house breaker for you washer should be rated at 20 amps.
If the washer is running and drawing less than 20 amps and the breaker trips then if can be a weak house breaker.
Mid cycle the washer is most likely draining or spinning and if the bearing or pump locks up then the washer may draw additional amps to try to start and trip the breaker.
The key to this problem is what the amp draw of the washer is when the house breaker trips.
To narrow this problem down, there are three places that could be causing the ( outlet) GFCI to trip, a malfunction in the washing machine, a problem with the downstream wiring (aka load side of the GFCI-other items connected on same circuit), or the GFCI outlet itself. If there isn't anything downstream, then plugging the washing machine into another GFCI outlet, or simply swapping out the outlet for a known good GFCI outlet, will identify if the outlet itself is faulty.
If the outlet trips when the washing machine isn't running and isn't even plugged in, then there's a fault in the wiring on the load side of the GFCI outlet.
If the issue is neither of the above, then running the washing machine and monitoring to see which step is occurring when the trip happens will isolate what part of the washing machine may be leaking current to a ground. It could be a certain water level, a motor being engaged, a transition step in the controller, etc
Beware some techs believe that most Washing machines or any other motor should not be on a GFCI! Should be a dedicated single receptacle. If there are other outlets on the washer GFCI, replace that GFCI with a single receptacle and put the GFCI on the next jump in order to protect other outlets.
Another item to check is ur lid switch which may have gotten moister inside and created a short_ or broken open and the rubber seal dried out over time, and the switch assembly will be exposed. water can splash onto the assembly, somehow causing the GFCI to trip. In any event, if you are having trouble with your washing machine stopping mid-cycle for any reason, test and replacing the lid switchis probably a worthwhile idea, as it is cheap and easy to replace.
By the way my advice is free cuz God is good!
Jan 03, 2017 | LG Washing Machines
Admiral washer. Did load of laundry, breaker tripped, and is still full of water. Reset breaker, and hear a small click after I pull knob to restart washer. Breaker trips. No leak, and outlet is good
If the washer ran additional loads the problem will not be an electrical short with one of the washer parts. If the lid switch had a short it wouldn't run the additional loads.
You don't say if the additional loads used the same cycle as previously. A timer can have an internal short that might trip the breaker in heavy duty cycle but not the permanent press cycle.
May 22, 2015 | Admiral Washing Machines
When put on a wash it trips the electric
May 10, 2015 | Miele Washing Machines
Es-f800ks washing machine is power supply problem..That means is when i plug in the power then just 3 second only comming..after that no power..I try it many time ..It's same things..
Mar 29, 2015 | Washing Machines
When plugging it in to the socket it powers up only for a minute then trips the power any ideas?
Mar 22, 2015 | Washing Machines
Ground fault keeps tripping
Mar 17, 2015 | Washing Machines
I got 2 wascomat gen5 that trips breakers only on rinse cycle
WDD960 washer dryer trips the RCD when it is plugged in even when the machine is not running. Is the answer a new machine or can it be fixed
Feb 21, 2015 | Dryers
LG Tromm washer tripped breaker, now won't come on at all
Jan 06, 2014 | LG WM0642H Front Load
Trips GFCI receptacle for laundry circuit.
I ran into this problem with a washer this summer. the gfi breaker needs to be replaced. it is weak and trips easily. if you can run an extension cord to an outlet without the gfi andrun your washer, you probably will not have any issues. that is what I found with the washer this summer. when it was plugged into the gfi, itwould trip. but when I had it plugged into a regular outlet, it was fine. Joe
Nov 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Frigidaire GLWS1233A Top Load Washer Logo
107 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
