Question about Panasonic Microwave Ovens
I have a Panasonic MW Oven (NNS255) I Cannot open the door. How do I get access to behind the control panel to fix whatever is broken
  • 3,037 Answers
The outer panel should come off from the back and bottom with screws. I believe that it will be a philips screwdriver that you need and once you remove the entire panel, you will basically have access to everything. Make sure you unplug it first and be careful to only work around the panel as I don't want you to get hurt.
good luck and let me know of any questions that come up while doing this
Posted on Aug 10, 2008
    Genius:
  • 2,920 Answers
You need to take the housing off the microwave to get to the door latch..once you get it open you should be able to find access screws to take the door apart to see whats broken.please rate me thanks
I have a Panasonic Microwave Model NN-SD277. How do you access the workings of the door opener button? It is broken so the door won't open.
You have to remove the outer cover, the plastic lift levers are behind the door open button / lever. Caution!, panasonic discontinued a lot of those and getting a replacement part can be hard at times. Dont waste your time trying to glue it. After watching people try to glue or epoxy those cheap plastic parts for so many years. I have to warn folks to not waste your time trying. .It will not hold!!!! Look online and try to find a replacement part somewhere. It will be one of two parts. the door open button you push, or the door open lever that the front button pushes against. If you unplug the unit and remove the outer cover simply look behind the front control panel and when you push the button to open the door you will see where it is supposed to lift to open the door. The broke part is your problem, may be a piece laying in the bottom.
Aug 14, 2017 | Panasonic Microwave Ovens
WILL NOT SHUT OFF, LIGHTS UP, TURNTABLE RUNS, MAKES NOISE, ONLY WAY TO SHUT OFF IS TO PULL PLUG OR OPEN DOOR
This is a classic door switch problem. I fixed a friend's MW a few months ago that had this exact symptom. Got a family member's MW going again last summer for similar (not identical) problem.
In our case, one of the switches was broken (shorted). There are usually a group of similar door switches all mechanically ganged together behind the latch. If the MW has a wiring diagram, you can use it to figure out which switch controls the light, fan and turntable. Check the switch with ohm-meter after you get it out. The switch plunger may have lost it's springiness.
You need to be clever mechanically to figure out how to disassemble for the R&R (remove&replace). Don't break plastic mounting pin or you may have to improvise repair for that too!. It may help to have the service manual for your particular model (worth a google search). The switch is probably relatively inexpensive ($5 or so) and a generic replacement should work fine if it has the same-or-higher voltage and current rating.
Apr 22, 2016 | Microwave Ovens
MW runs when Door is opened and stops running when door is closed
It's almost certainly a defective door switch or switch mount.
My complete text file on door switches is here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
mini_manual_behind_grille_small.jpgdee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Oct 15, 2011 | GE JVM1650 1000 Watts Microwave Oven
NN-T774 INVERTER STOPPED WORKING AFTER 4 WEEKS
Check to make sure one of the plastic hooks on the door was not broken off. If both door hook latches are functional then the most likely cause of your problem is one of the latch switches located behind the control panel. These switches will fail if the oven user opens the door frequently BEFORE the cook cycle ends. Always push STOP/RESET before opening any microwave oven door.
Dec 30, 2009 | Panasonic Microwave Ovens
JVM1850BH02 Microwave completely shut down, not working after...
The extreme heat has opened up one of the thermostats / thermal cutouts (TCOs) in the oven.
If it was the bottom TCO or magnetron TCO, you should be able to access them by just removing the control panel.
But if it's the one on top of the cavity, the oven will have to come out of the wall, then you need to pull of the outer cover..
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You should locate and look this over first.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Fmv156dsb, when the timer is on you have to push up
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Dec 11, 2008 | Frigidaire FMV157GM Microwave Oven
Panasonic door won't open
the main cover of the microwave needs to be taken off so you can get the door opened and then you should have access to the screws that hold the door together. the housing is the main part of the mw and once its off you should be able to open the door from the inside and thus be able to work on the door latch..please rate me thanks
Aug 10, 2008 | Microwave Ovens
Oven door
It's probably not the spring.
It's probably a broken spring mounting tab on either the inside panel of the oven or the "door key", which is the part that has the hook like projections that go into the chassis behind the door.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can order Panasonic parts here: http://www.pasc.panasonic.com/epartr
(select Order Listing ByPart Number) when searching
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 14, 2008 | Panasonic NN-S254BF Microwave Oven
Panasonic MW- Arcing
You're on the right track. That panel is the waveguide cover.
This is usually due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover in the waveguide just out of sight.
It can be fragile, and the metal edges behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smmoth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
If your waveguide cover is burned, it will need to be replaced.
To order Panasonic parts see http://www.pasc.panasonic.com/epartr
Nov 07, 2007 | Panasonic NN-T990SA Microwave Oven
Stuck Microwave door
In most cases this is due to a broken door opening lever or loose or broken door latch / hook parts. They can only be accessed and examined if the cover is removed from the microwave. In many over the range models, you can access the door parts by removing the control panel assembly. Sometimes you may be able to get it open by pushing up gently on the bottom of the door while pushing the button, in case you need to empty it.
Jul 30, 2006 | Whirlpool MT4070SK 700 Watts Microwave...
Microwave Ovens Logo
44 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
