Question about Game Elements GGE900 (51691)
GGE909 I'm running Windows Vista. When I try to use the GGE909 with a flight simulator it keep telling me that is has to update the code for this controller. Also, I have EA Sports game collection. When I run it, it does not even recognize the GGE909 controller. Do I need to upgrade the driver? Please help.
Loaded but wont run when activated
Check this link for more info...
Also don't know your OS ?
Flight Simulator 2004 doesn't run correctly on Windows 8. It runs on my Windows 8 laptop bought in April 2013. But, none of the aircraft, including any add-ons, show up in the preview window - it is always black. Also, If I download weather and try to save a flight, when I go back to that "saved" flight, it always reverts to the default flight with the Cessna @ the default airport. If anyone knows how to make the flights save, on the Windows 8 platform, please let me know - likewise, with the aircraft previews. Flight Simulator 2004 did quite well on the Windows XP platform for me.
Apr 18, 2014 | Microsoft Flight Simulator 2004 Update
I can't run my flight simulator on win 7, get same error as others on vista: d3drm.dll not fopund
Hello Larry,
Download the above file from dll site, unzip it and install it. If the problem still persists then use a system utility software like RegInOut to fix corrupt registry & windows files.
Hope it works for you.
Jan 04, 2012 | Microsoft VISTA Computers & Internet
D3drm.dll i cant load it for flight simulator
is the flight simulator compatible with vista? Do you have all the needed requirments.
If yes to the above then try scanning the pc for errors.
On the other hand right click the setup and choose compatibility from the list and set it to a previous version of windows (example windows xo service pack 3) and select the run in administrator mode. Apply the changes and reinstall. You can again right click (that is the setup) and select run as administrator for the game to have full access to the pc.
good luck and do let me know of the outcome
Jul 04, 2010 | Microsoft Windows Vista Ultimate Edition
The tutorials in MS Flight Simulator X unexpectedly stop
this is Easy... so when he talks he tells you what to do as you go along so do
EXCATLY AS HE SAYS then he will keep going. Also Your Computer May Be old.
Feb 05, 2009 | Microsoft Flight Simulator X for Windows
When I bank right or left with joystick the screen Freezes
To check the joystick isn't the problem, go into control panel game controls, then check that the joystick appears and you can move the cross-hair around on screen, most modern joysticks are
auto-calibrating, but you could try running the calibration.
To check the game isn't a problem, unplug the joystick, then use the arrow keys to fly the plane, if it doesn't crash when you bank then it isn't the game.
I assume the game is Combat Flight Simulator 3, as very old games that were written for Windows 95,98,ME series often won't run on Windows NT,2000,XP,Vista as they are completely different versions of Windows. If this is actually Flight Simulator 3, you may need to consider buying a later version of Flight Simulator (FSX is the latest version, but may not run on your laptop).
Other things to try are updating the graphics card driver.
Norton shouldn't need deactivating, although it could cause problems if you're playing online.
Also remember that laptop graphics cards are never as powerful as desktop graphics, and games very rarely specifically support laptop graphics.
Hope this helps.
Jan 21, 2009 | Logitech Extreme 3D Pro Joystick
I can not run flight simulator becoz,d3drm.dll has not been found
U can go to google.com And Search for   '' d3drm.dll download it .....
Jan 16, 2009 | Microsoft Windows Vista Ultimate Edition
Game Elements GGE900 (51691) Logo
270 people viewed this question
Top Game Elements Video Game Consoles & Games Experts
Ekse
Marvin
Marvin
Are you a Game Elements Video Game Console and Game Expert? Answer questions, earn points and help others
