Question about Canon P23-DHIII Calculator
LOADING NEW PAPER
HOW DO I LOAD NEW PAPER? I AM TIRED OF THE MERRY GO ROUND OF REPETING THIS QUESTION A DOZEN TIMES WITH ONLY ANOTHER "DESCRIBE YOUR PROBLEM" FOR IT. WHER IS CANON IN THE CHAIN OF THINGS?
Tear or clip the end so that it has a fairly even point in the center. Place your new roll on the paper bail with the point facing away fron you. Insert the point in the slot on the back of the calculator. Press the paper advance button (the arrow above the division button) until the point clears the serrated cutting edge. Carefully pull back toward you to tear it.
HTH
Posted on Sep 04, 2008
HOW DO I LOAD PAPER INTO THIS
Posted on Aug 25, 2008
SOURCE:
Epson T60, Paper Loading Problem
Jumped through outside the tray? Plz, describe more clearly. Epson T60 is "best design" in paper feeder for A4 size printer. I have a lot.
Jan 23, 2013 | Epson STYLUS PHOTO T60 INKJET PRINTER
IMy wife pulled the paper tray completely out of
Loading your paper
Paper loading tips:
● Load paper with the side to be printed facing down.
● You can print photos and documents on a wide variety of paper sizes, from
8 x 13 cm (3 x 5 inch) up to 22 x 61 cm (8.5 x 24 inch). The 10 x 15 cm
(4 x 6 inch) photo paper is available with and without tabs.
● Before loading paper, pull the Main paper tray out (use the Main tray release or
the tray grips) and slide out the paper-width and paper-length guides to make
room for the paper. After loading paper, adjust the guides to fit close to the edges
of the paper without bending the paper. When finished loading paper, push the
Main tray back in all the way.
● Load only one type and size of paper at a time in the same tray.
● After loading paper, extend the Output tray extension to catch your printed pages.
Use the directions in the following table to load the most commonly used paper sizes
into the printer.
Paper type How to load Tray to load
Any supported
photo or plain
paper media
1. Extend the Main tray by
pulling it out with the Main
tray release or the tray
grips.
Load the Main tray
Chapter 2
(continued)
12 HP Photosmart 8200 series
2. Slide the paper-width and
their outermost positions.
3. Load paper with the side
Check that the stack of
paper is no higher than
the top of the paperlength
guide.
4. Adjust the paper-width
inward until they stop at
the edges of the paper.
5. Push in the Main tray all
the way in.
6. Make sure the light on the
Photo tray button is
turned off to enable
printing from the Main tray.
Load paper and adjust guides inward
1 Paper-width guide
2 Paper-length guide
1 Push the Main tray all the way in
Aug 03, 2010 | HP Photosmart 8250 InkJet Printer
Canon MP145 Error 2
Just press the green (color) button about 5-10 seconds. Hope this help a bit.
Mar 25, 2010 | Canon Office Equipment & Supplies
Loading paper into the Canon P170-DH Desktop adding machine
Rather than try to describe the process in words ("lift up the arm, then feed the paper through..."), I'll point you at the illustrated instructions in the manual at the manufacturer's web site: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=349&modelid=9785
Mar 03, 2010 | Canon P170-DH Calculator
Canon pixma 3100 keeps saying load paper and won't print
If you have paper in the loading tray and it keeps giving you out of paper message then the sensor by the loading hopper is not working and would need to be replaced.
9 times out of ten though you might want to clean the printer and make sure the hopper is not just jammed this happens when you put too much paper in there at one given time.
thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sep 17, 2009 | Canon PIXMA MX310 All-In-One Printer
I am having trouble loading paper into my Canon MP190 Printer?
Try loading less paper AND try this trick:
Holde the stack of paper you are going to load with both hands... grip tight with the right hand and "bend" the paper like an arch. Then grip tight with the left hand, loosed grip with right, and "bend" the paper like a valley. Repeat this a few times to quickly seperate the individual pages so they don't stick together and thus jam in the printer!
Hope this helps!
-- RT
Sep 01, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Printer won't print documents and has trouble feeding paper
did you make sure to remove the tape covering the end of the cartridge?
Jul 15, 2009 | HP Photosmart 2575 All-In-One InkJet...
Paper not detected in cassette
do you have the paper in the correct position? you can feed from the top or the bottom but you need to select the correct one. hope that helps
Mar 11, 2009 | Canon MP610 Photo All-In-One Printer
Loading cut sheets
Try to check the paper media set on the plotter (roll/plain paper). It usually happens if paper media is not the same with the plotter setting. To change it, unload the paper, press the media button on the printer to the right media and load the paper again. It should work now.
Dec 06, 2007 | Canon iPF700 InkJet Printer
Not loading paper
i have the same problem no matter how many times i load paper it still says out of paper
Nov 12, 2007 | Lexmark P4350 All-In-One InkJet Printer
Canon P23-DHIII Calculator Logo
323 people viewed this question
Clive
Clive
old marine
old marine
Ekse
