Question about Dishwashers
Top drawer on Fisher Pakal model DD603 B-won't turn off. Keeps scrolling through the numbers. No particular error code. Can't select type of wash or anything else.
I have the same model and the same problem. I just emailed FP and will let you know if they answer.
Posted on Sep 25, 2008
F3 code and beeping noise
Not sure which model number dishwasher you have. But usually F3 error means a water temperature related fault. The water temperature is too high. Hopefully you are not using the hot water supply of your house. If so then ensure it is less than 80 deg C. If using normal mains supply (cold water) then it is likely the temperature sensor in dishwasher has failed. Not an easy job to fix as it is integrated into the water heater element at the base of the drawer for the DD603 drawer type dishwasher.
Mar 19, 2013 | Fisher and Paykel Dishwashers
Fisher and paykel dishdraw model DD603
P2 is for drain. Make sure there is a bit of water in the base of drawer before you start P2 otherwise the rotor may rub and burn. You can run the diagnostic with drawer open. Be careful not to start P1 as the wash water will splash and flood the dishwashwer.
Jan 28, 2013 | Fisher and Paykel Dishwashers
MY FISHER AND PAYKEL DD603-SS BOTTOM DRAWER IS NOT DRAINING. HOW DO I FIX THIS?
Do you get any error code on the display?
Does the cycle complete or dishwasher keeps running?
Do you hear the pump trying to drain?
Is it happening in all wash cycles or some?
The easiest thing to do is to check if the filter at the base is clean.
I am assuming the kitchen drain is clear because the other drawer seems to work normally.
Oct 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My model number is DD603 The top dishdrawer is draining into the bottom dishdrawer. What is the code to reset the drawers?
the check valve in the bottom drawer may be clogged or defective. the two drain hoses are probly connected to become one.
Jan 20, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
E-mail for Fisher Paykel DD603 manual
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
May 05, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher & Paykel DD603 setting the water pressure
First off, clean the surface where you select the cycles, over on the right side of the drawer edge. Clean up the entire surface, so that when you lightly touch the cycles, It changes instantly. Also, you said "dd603" but the LP/HP modes are for model 601 and 602.
Open the drawer, select normal first. Now with two hands, hold your fingers over the two outer-most buttons, one on the left side and one on the right. Wait up to six seconds and then the LEDs should all come on in an orange color and the display should show the LP. Press the lock button once, it should change to LP. Make sure you are looking for a manual for a dd601/602. You can get them free at http://www.fisherpaykelparts.net
Dec 02, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel DD603 service manual
Check to see if the Child lock is on...Check your email
Aug 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel DD603
The top drawer on our DD603 top lid doesn't seal allowing water to spray out and down the sides.
Aug 10, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
None use for 7 days
I have a fisher paykel dd603 dishwasher. If I select the normal wash setting on the top drawer, it posts the time in the lcd screen as 56 mins. The unit will wash as usual until it reaches the 28 min mark. At this point it will stay on 28 mins and continue to run, but it won't rinse or empty the drawer of water. Also it never counts down below the 28 min mark. It has flashed a F4 and F1 code. I've cleared them both, and checked to make sure that no water is standing on the bottom of the unit, and that the heating element is working. I should mention that the top drawer did overflow about two weeks ago, and that I did clean up the water. I don't know where to look from here. Any suggestions?
Sep 10, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
96 people viewed this question
Top Dishwashers Experts
