Question about KitchenAid KAWS850L Top Load Washer
Kitchen aid washer
My washing machine will not hold water in the tub
  • Duane Grant
    Duane Grant May 11, 2010
    is the water running out from under the washer? please give more detail?
  • 640 Answers
Your drain hose is to low,,,must go up height,,of top before it can go down...onthejob
Posted on Jan 31, 2009
How to remove the drum from a kitchen aid washing machine
hello. Unplug the washer and use a vacuum cleaner to remove the little balls. J.
please rate my answer as very helpful. Thanks.
Mar 28, 2010 | KitchenAid KAWS700L Top Load Washer
How does the wf430 hotpoint washing machine drain
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Not too sure what you mean but will try to explain. The water in the tub is only kept there because one end of the outlet hose is higher than the tub and the job of the pump is to push the water up the hose and out. If the outlet hose is lower than the tub, all the water inside will just flow out, the pump does not hold the water in the machine it only assists in its removal. If you remove the pump from the machine altogether then the water will just flow onto the floor but if you disconnect the pump from the wiring circuit it will just mean you have no mechanical way of emptying the tub. However if you lower the hose to the ground then by the force of gravity the water will flow out. Just one other point, the hose should come out of the machine and rise up the back of the cabinet then loop down again where it fits into a stand pipe or is connected to a waste pipe, if however the end of the hose is lower than the tub you will get a siphoning effect happen after the first pump out in which case the water from the machine will just empty on its own without the aid of the pump. For more Hotpoint aid visit Selfix-uk
Mar 11, 2010 | Hotpoint WF430 Front Load Washer
I have a top load kitchen aid washer that works but when it agitates it is not straight ..it is on an angle and it is a direct drive (do I go thru bottom or top) and what is the problem???
Remove the 2 screws from corner of the control console and lift the console to the rear. Remove the 2 clips holding the cabinet to the rear panel. Unplug the lid switch wire. Remove the cabinet. Look for a loose or broken spring. There will be 3 large springs around the base. One small spring goes from the tub to the bottom rear panel(probably the one broken).Look for a loose skate plate under the tub. Maybe missing pads.
Sep 19, 2009 | KitchenAid KAWS700L Top Load Washer
My washer fills the tub, but when it goes to next cycle just hums
Your motor has failed.
Remove it from the washer to have it repaired or replaced.
Thanks
:D
Jul 20, 2009 | KitchenAid KAWS850L Top Load Washer
Trying to replace clutch on kitchen aid clothes washe, cant pull gearcase off . have moter removed already.
There are 3 bolts holding the gearcase on. Remember to remove the agitator from the tub first.
May 11, 2009 | KitchenAid KAWS850L Top Load Washer
My kitchen aid superba won't spin until i take wet clothes out close the lid again so that it begins to spin while empty, and then return clothes and it will usually spin then, unless a heavy load, then i...
I think that you have a bad drive block. It is located under the inner tub and the agitator. It is a pretty intense repair if you have never replaced one.
Feb 28, 2009 | KitchenAid KAWS850L Top Load Washer
Eco smart won't drain, smells hot
hi
you commented on hearing water in the machine after the wash , i know that f&p spin bowls have a liquid inside the actual spin bowl system i think it aids in the spin operation of the machine, but if you had something in the drain network then that will stop the machine from emptingout as it all works on a time basis check and see that you are not getting any leaks from the bottom of the machime as your new pump won't last long if it gets wet also if there is water leaking that can be the main seal on the motor shaft failing
cheers grant
Oct 19, 2008 | Fisher and Paykel GWL11 Top Load Washer
SPin CYcle Noise
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump. Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then try to remove the clothing through the port.
Apr 16, 2007 | Kenmore 42722 Top Load Washer
KitchenAid KAWS850L Top Load Washer Logo
46 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
