Question about Dishwashers
KITCHENAID KDC-21A - Julie Ohio problem
How do I check the fuses. The outlets next to the dishwasher work.
Thanks you
    Genius:
  • 1,689 Answers
Hi Julie, the fuses of the washer is right on the control board, you may refer to the picture and the link i osted in your previous thread to exactly locate it.
Posted on Aug 10, 2008
Kitchenaid dishwasher KDC-18 works but the water does not get hot just cold. Any solution?
Dishwasher must be connected to a hot water line in order to work properly. Also, it often requires a good deal of time for hot water to make its way from the water heater to the dishwasher. If the dishwasher is located under the kitchen counter, turn on the hot water in the sink until it runs hot, then start the dishwasher.
Many dishwashers have a built in heater, but hot water should be initially fed into the dishwasher through the water inlet in order for it to perform properly.
Mar 17, 2013 | KitchenAid Dishwashers
My KitchenAid dishwasher quit workin no light no nothin, float switch is good, having problem troubleshooting water fill valve with solenoid???
Hi
Thanks for using FixYa. Please check for the following if your dishwasher is not working--
1. Fuse (blown or tripped).
2. 120 VAC supply wiring connection faulty. Repair or replace wire fasteners at dishwasher junction box.
3. Electronic control board faulty.
4. Motor (inoperative, check resistances).
5. Door switch (open contacts).
6. Door latch not making contact with door switch.
7. Touch pad circuit defective.
8. No indicator lamps illuminate when START or OPTIONS is depressed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 18, 2009 | KitchenAid Dishwashers
I own a KUDS01FLSS3 KitchenAid dishwasher. The lights on the control panel do not come on and a cycle can not be started. There is about an inch of water in the bottom of the dishwasher basin and it looks...
The problem with the unit is the thermal cut-out/fuse has tripped. You'll need to purchase the replacement kit #959376. It should be available at most local parts retailers, or online parts depots as well. (double check with your model number, but that is the most common)
**Be sure to use the entire kit**.
You'll notice there are new wires to the fuse to be spliced into existing ones, this is to ideally prevent the problem from re-occuring. (follow the instructions provided, you'll be fine)
If the problem does re-occure in the near future, you'll need the control, #1060952
hope that helps,
Good Luck
Oct 18, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid dishwasher, control panel is not
I don't know your technical ability, but there is a fuse located next to the control board inside the console, this is a good place to start. Kitchen Aid is good about putting tech sheets on the back of the kickplate and it should have wiring and diagnostic info there. Just be sure to put the sheets back so the next service tech to work on it will have them :)
Sep 01, 2009 | KitchenAid Dishwashers
Kitchen Aid dishwasher model KDC-18 is not filling with water
Under the machine is the water inlet valve. if you take off the front end of that you find a filter which fills up with rust, and you can clean it out. If that doesnt work, repairclinic.com will sell you a new valve for 32
Jun 13, 2009 | KitchenAid Dishwashers
Kitchen aide dishwasher KUD101IL control panel not working
1. Check plug outlet.
2. Check electrical box underneath the d/w where power cord connected to d/w (you have to take the kick panel off . The box located on right side). Sometime you can find burn wire there.
3. Check the thermal fuse on computer board. It is inside the control panel on right hand side. The fuse has 2 white plastic connector which sticks out, easy to find.
Dec 08, 2008 | KitchenAid Dishwashers
No power at all
hi there,
can you hear the motor running? then it's the main control board. if you can hear it, that means you have power and i would check the keypad on the very front.
please let me know how it goes.
thanks
Sep 28, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
Dishwashers Logo
104 people viewed this question
Top Dishwashers Experts
