Drain line is stopped up, overflowing and dripping into light fixture in hall way
  • 182 Answers
Need to cut and clear drain line.maybe install a removable rubber coupling so its easy to repair next time
Posted on Aug 10, 2008
DRAIN PAN FULL OF WATER AND OVERFLOWING ONTO FLOOR
What kind of unit do you have? Its possible depending on the manufacture that a water line is the cause as it drips water into the pan causes the overflowing of the drain pan. Look for cracks in all the water line under the unit and you may have to remove the back and the water valve to see it. Good luck
Mar 07, 2015 | Refrigerators
Kenmore side by side ref model #58582891 water line leaking in bottom front of refrigerator, replaced the filter housing, stopped the leak that went into the drip pan. Water drips in front when push the...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 11, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
MLG LS307HV. Condensation is dripping off the bottom of the indoor unit. We've mounted the unit level but the left side continues to pull up. The wall mount is level but he unit is slightly out of...
the inside unit should be mounted with a slight tilt to the outside - so the water can drain outside.
also - be sure your drain hole (in the unit) is not plugged - either with dirt/debris.
Aug 04, 2011 | LG LS307HV Air Conditioner
Drain Pan overflowing and water is leaking in refrigerator I can see drip pan overflowing but I do not know how to get to it
remove the back panel inside the freezer,then defrost the pan,then take a length of stiff wire and clear out the drain line from there down to the pan in the lower area near the compressor,as theres probably lime,mold growth build up in the drain line plugging the hose restricting draining of defrost water
Mar 03, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is dripping from the left bottom edge of the plastic facing on the side by side Frigidaire stainless steel refrigetator (Model GLHS268ZDS7). How would take the facing off to inspect the water valves?
Have to see if there is water overflowing in the drain tank from defrost section that is leading to the water dripping.
It can also be the leak from the plumbing lines to the fridge , if so you will have to remove and reset the pipe connectiion so as the leak stops using good silicon tape as bandage.
Sep 24, 2010 | Refrigerators
Intertherm Air Handler Coil leaking water
replace it it's junk - going to do that this time because this is the fourth year of the same problem on the hottest days this intertherm junk downflow ac unit condensates where it will not and con not be captured by the pan - built by relatives of the guy who designed the titanic -
Apr 07, 2010 | Intertherm P3RA-024K Air Conditioner
Excessive water dripping from Central A/C drian line
sounds like the overflow drain is picking up the water that means the main drain is clogged.you need to find the main drain pipe if lookin at the air handler in attic there should be 2 drains from unit one higher than other follow it and blow out drain they put the other overflow drain out the eve so if it stars leaking someone notices it and it doesnt damage cieling but it sound like it needs imediate attention befor it does go to the overflow pan and damage your cieling. i hope this helps and good luck
Sep 29, 2009 | Amana PTC153B35AJ Air Conditioner
The feeder tube for the ice maker freezes and water leaks inside
First we have to determine if the problem is a faulty water valve. Reason: faulty water valve can continue to supply water even after the IM or door dispenser is finished calling for water causing a drip feed freeze up problem, or water overflow condition in the ice maker (IM). Another common cause is unrelated, but caused by a blocked drain line often resulting in thick ice build up on the bottom of the freezer, water dripping onto the floor, or water dripping into the refrigerator (top freezer mount models only) and freezing near the lights or damper ducts after defrost. Fix for this problem is to remove evap panel and clear freezer drain line with hot water or compressed air. If this is not the case, and water is dripping out of IM supply line, remove IM H20 supply line from IM at back of appliance and see if the water seems to drip out, if so, replace the water valve. If water doesn't drip out at all, replace IM, or IM module depending on the model of refrigerator that you have as contacts in the IM are also responsible for calling for H20 supply. You will have no more problems after this.
Jun 17, 2009 | GE GSS20IEP Side by Side Refrigerator
Hi, I have water dripping from my a/c, on the inside
The condensate drain line is probably clogged.
Find out where the pipe exits the home, and attatch a wet/dry shop vack to the end of the drain line, close it up around the pipe as much as possible and trun it on.
These typically get clogged with dust, dirt, pet hair, mold etc.
They usually clog at the elbows, P-traps and the inlet coming from the drain pan. There is an internal drain pan in the unit that catches the condensation. When the line clogs the pan overflows and you have water dripping from the unit.
There is also a small chace the pan has a hole in it, but thats fairly rare. There is also a chjance that if the unit is not level the water will overflow the pan before it can drain. (most pans are only 1 to 2 inches deep.) Make sure the unit is level or veryslightly lower toward the drain side.
Dec 09, 2008 | Heating & Cooling
Water leaking from refrigerator
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
If you just want to clean it you may can access it from the rear behind the cardboard backing. If it's overflowing your water filter may be stopped up or you may have had an excessive amount of frost one time.
Jul 09, 2008 | Roper RS25AEXLQ Side by Side Refrigerator
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
