Question about HP Photosmart E327 Digital Camera
"Card locked" I dropped my camera, and now when I turn it on and try to take a picture, it won't click and just says "Card locked". How do I solve this?
    Genius:
  • 1,689 Answers
Will you take the card out and see if you will be able to use the internal memory of the camera.
if in case it will work, check your SD card if it is in the LOCK position,
if it will not work, i sugegst you consult a local repair shop to have it checked, because there is a possibility that a part has been damaged.
Posted on Aug 10, 2008
SOURCE:
CameraWindow won't open or will suddenly close before loading
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jun 03, 2012 | Canon PowerShot S90 Digital Camera
Card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here. If these don't help, and you do end up having to format your card, see the recovery software, along with the corrupted card procedures in this blog article.
Nov 18, 2011 | Canon PowerShot SX130 IS Digital Camera
I'm not able to connected my camera canon A420 with my PC and the 2 problem is that it is showing card locked wen i start the camera how to solve this problems
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use ZoomBrowser or any other photo cataloging program.
Jul 03, 2011 | Canon PowerShot A420 Digital Camera
Trying to transfer pictures to computer. With camera turned off I plug in the kodak usb cable, then try to turn camera back on. Camera will not turn on. Battery is charged.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jun 12, 2011 | Kodak Easyshare M381 Digital Camera
I had connected the camera to my computer to view my photos, and the camera locked up. The screen shows 59% and won't change. I can't turn the camera off either. Help! I don't want to lose my pix or the...
Disconnect the camera from the computer then remove the batteries.
To download your pictures, try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Mar 28, 2011 | GE Create Leather Jason Wu Digital Camera
I am using Windows 7. When I try to acquire from PC, the word "ACCESS" flashes on the DMC-FX8 camera screen continuously but the Lumix View Finder cannot find any pictures. How can I solve this...
Dec 28, 2010 | Panasonic Lumix DMC-FX8 Digital Camera
I took several pictures this morning. Then I plugged the camera into the cradle and pressed USB port and connected the line from the cradle to the computer, an operation I have completed numerous times. ...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Oct 04, 2010 | Casio Exilim EX-S600 Digital Camera
Pictures will not transfer to the computer.......
Apr 21, 2009 | Kodak EasyShare C613 Digital Camera
Locked lense
Try these procedures.
Nov 07, 2008 | Kodak Easyshare M753 Digital Camera
Card locked
SD memory cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jul 06, 2008 | Vivitar ViviCam 3740 Digital Camera
HP Photosmart E327 Digital Camera Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
