Need to lift the engine slightly to remove leaking oil pan. What is the best way to do this and support it and how high does it need to be lifted.
I do not have a proper motor lifting device.
Lift our car remove the motor mounth and the braket to its easyer most of the time that mounth is broken lots of oil on it remove starter disconnect battery under the trasmission on the housing not the pan put a leg or a jack lift it up as high as possible remove oil pan bolt remove and repeat step dont forget to remove that braket and mounth thanks pierre
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pan-on-2008-honda.html
How to replace Oil Pressure Sensor on 2008
Honda Odyssey?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pressure-sensor-on.html
2004 Chevrolet Express Van: Oil pressure
sending unit replacing?
http://whoisbyme.blogspot.in/2012/06/2004-chevrolet-express-van-oil-pressure.html
HOW TO REPLACE AN OIL PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pump.html
HOW TO CHANGE ENGINE OIL AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-engine-oil-and-filter.html
HOW TO REPLACE AN OIL PRESSURE SWITCH (SENSOR)
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pressure-switch.html
How to
Check Differential Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
HOW
TO RESET OIL CHANGE INDICATOR?
http://whoisbyme.blogspot.in/2012/07/how-to-reset-oil-change-indicator.html
These details will help.
Thanks.
The engine in question is a 2.8 litre in a 1989 Pontiac 6000 S/E
