Question about Garmin Nuvi 350 Car GPS Receiver
Nuvi 350 wont charge with car adaptor. But charges with ac charger in usb port of Nuvi. Any thoughts? I have another Nuvi 350 that does charge with this ones car adaptor.
  • Anonymous Feb 11, 2009
    Mine does the same thing. The charger keeps blowing the fuse for the lighter.
  • 174 Answers
Try this, start your engine and then plug in the nuvi car adapter. The nuvi should turn on by itself. If the nuvi doesn't turn on either the adapter is defective or the cigarette lighter is no supplying power. Try the same test on another car if it works then I would say that the cigarette lighter power supply on the first car is defective, but if it doesn't then I would say that the nuvi adapter is defective. BTW there is a fuse inside the nuvi power adapter which might have blown.
Posted on Aug 27, 2008
Are you using the same port on the Nuvi to connect the car adapter and the ac charger, or two different ones? If not, then the jack could be broken (solder joint, pin?).
Posted on Aug 12, 2008
Shut off
You should only see the computer icon when plugging the 350 into a USB port on the PC. If you see it when plugging in a car charger/adapter, then there may be a problem with the mini-USB port on the 350 or the charger is an after-market charger that is not electrically compatible with a Garmin charger. Please see this link for more info:
http://www.sharc.net/gps_charger_repair.htm
May 29, 2013 | Garmin Nuvi 350 Car GPS Receiver
HOw do you charge it?
This unit comes with a charger (AC). There is alxo a car charger. Both have a USB connecter that plugs into the side of your unit.
Sep 20, 2011 | Garmin nuvi 350 GPS Receiver
My bracket for my suction mount broke so I cant use a cigerette lighter charger is there another way to charge my GPS
If you were using a standard Nuvi 3xx cradle, pull the charger cord from the back of the cradle and plug it into the side of the Nuvi, into the mini-USB port. You can charge it that way.
- Jim
SHARCNET-USA
Oct 24, 2010 | Garmin Nuvi 350 Car GPS Receiver
Cant use the garmin 350 while charging
The solution is really easy. Works in the car or usb charger or whatever.
Once you insert the car charger, wait till the pc connection picture comes.
Than unplug the car charger.
Re-insert it as soon as the picture goes off.
Voila. It is ready to use now!
Feb 08, 2009 | Garmin nuvi 350 GPS Receiver
Garmin gps won't charge while driving
If the Nuvi won't charge when connected to charge but charges on USB, then the charger port is faulty.
If the Nuvin does not charge at all , then the battery must be replaced.
Dec 27, 2008 | Garmin Nuvi 350 Car GPS Receiver
New Nuvi 760 that won't work
Using the PC to charge a Nuvi is not the correct way to charge. Use either the AC wall charger or DC car charger. Many PC USB ports can not supply enough current to charge a Nuvi.
- Jim
Dec 12, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Is the battery in my Nuvi 350 rechargeable, and if so, how do I do it and how long does it take
Yes, the battery is rechargeable and can be charged (3) ways:
1. Car charger.
2. Wall charger.
3. USB cable (less advisable due to current limits of USB port).
A new Nuvi is shipped with all (3) charger/cables. Overnight charginging is ideal.
- Jim
Oct 03, 2008 | Garmin GPS
Nuvi 350 does not hold a battery charge.I see no way to change battery and the owner manual does not say how.
How old is the unit? Does it show that its charging with a lightning bolt over the battery indicator? Don't try to charge it via the USB port. Try the car adapter or AC wall charger.
Email me at ks3r at sharc dot net and I can replace the battery for you.
- Jim
Aug 21, 2008 | GPS
AC charging problem
okay if it charges with your DC, and it gives you plomebs with the AC, i would only charge in the car because your AC charger must not be changing the current to volts and you can easily blow it up... you can buy another charger and that should solve your problem
Dec 24, 2007 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 360 power problem
You'll need to open the case and replace the battery. Batteries can be purchased online here or a couple other places on the web by searching for "nuvi 360 replacement battery". I'd get the 1400mah or greater for a replacement, it'll burn a little longer than the weaker models. If the unit operates when plugged into the charger, then the fuse and cable are good. Open the case by removing the retaining screws, then carefully prying the unit apart. The new battery simply plugs into the connector after removing the old one.
Nov 13, 2007 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 350 Car GPS Receiver Logo
726 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
