Question about LG WM-2277HW Front Load Washer
Tub clean function
I canot get the tub clean function to activate. how do you do it?
  • Anonymous Aug 14, 2008
    I'm having the same problem.  I've tried everything but the function won't activate.
Found this answer in Fixya.com and it worked for me.
The Spinsense option has to be turned off in order for the Tub Clean option to work!
Posted on Aug 14, 2008
SOURCE:
The Tub Clean function never ends
why do you use tub clean function, we have never had the need to reclean the tub having just run hot detergent and water thru it .
Oct 04, 2015 | LG WM Washing Machines
I've tried all suggestions from other posts but still can't get Tub Clean Function to work.
Only suggestion I have is to try these old reset solution that work on some older lg washers: unplugg and wait 5 minutes or so, or unplug an d hold power button for 15 seconds, or unplug and the plug back in holding power button down for about 15 seconds then release. Good luck. (LG makes great products but their customer service and repair are horrible).
Mar 31, 2015 | LG Washing Machines
Galbocca tub with jets
You have some bacteria build up on the inside of your tubing of the tub.
Try some cleaning solutions per directions on the bottle of tub cleaner made specifically for this situation.
Cleaning Solutions
US Parts Center
Aug 22, 2013 | Whirlpool Home
Power to machine but will not start a cycle
If child lock has been activated, all buttons on the control panel except for the power button will be inoperable. Child lock is usually activated by pressing either the [pre-wash] or [tub clean] button for 3 seconds. To deactivate the child lock function, press and hold the same key again for 3 seconds.
Try switching the machine off by pressing the on/off button. Press the same button after a few seconds to restart the machine.
Mercedes Parts
May 25, 2012 | Washing Machines
LG Washer WM2455H Tub Clean Problem
Yes, it's normal. It is a safety feature because of the hot water used during the tub clean cycle. It prevents the machine from opening while the tub clean cycle is in process.
Jan 02, 2010 | LG WM2455 Front Load Washer
Can not activate tub clean
Please follow the bellow mentioned steps to activate the tub clean .
- First select "rinse and spin," then press "tubclean" for 3-5 seconds.
Hope this fixes the issue.
God Bless.
Jul 09, 2009 | LG Washing Machines
I have the spinsense option activated. I want to turn it off and I want to activate the tub clean option. The won't work when I press and hold the button for 3 seconds. What can I do?
Push and hold Stain Cycle button for 3 seconds to cancel spinsense. Then, turn off machine. When you power it back on, press "Extra Rinse" for 3 seconds and push the START button.
When cleaning tub, do NOT use detergent--only use liquid chlorine bleach.
Jul 05, 2009 | LG WM2487H Front Load Washer
LG WM-2277HW Front Load Washer Logo
606 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
