Question about Amana Dryers
Dryer belt broke but unable to open to get to it. having problem taking top of dry off. modle #LG8459w.
    Genius:
  • 2,920 Answers
There should be a few srews along the top at the back .once they are out u should be able to slide the top forward i think to release the catches that hold the top on.
Posted on Aug 11, 2008
I turn on my Whirlpool Cabrio dryer and everthing comes on litke its drying but the drum is not turning?
Have you checked the belt? Open the dryer cabinet to see if the belt has broke or come off the pulleys.
Jan 30, 2011 | Whirlpool Dryers
Belt broke and drum will not turn
replace belt order belt using modle number,,,check tension pullys also for damage,,,,,,,,,www.myabcspace.com/washerwizzards
May 17, 2010 | Dryers
Dryer drum stopped rotating, dryer blower continues to work.
The belt probably broke, and coincidentally happened while drying the shoes. The belt is easy to replace. Open the back and you'll probably see the belt laying on the bottom
Nov 10, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Dryer drum does not turn
Most likely the belt broke, replace the belt
Aug 14, 2009 | Dryers
DRUM BELT BROKE
To replace it won't be hard. Just make sure it is back on securely.
Jan 08, 2009 | GE DBSR453EBWW Electric Dryer
Kenmore elite quiet pac 9
unplug dryer, then take the top off and check your connections to door switch.i believe this model has a broke belt switch.open the bottom with the machine unplugged and reach inside and see if the belt is broke.if it is then replace the belt.
Nov 03, 2008 | Kenmore Elite HE4 Electric Dryer
Seimens wt 3301 How to install a belt
hi
it very simpel
opening back and top of the dryer
opening back bearing - by 4 small scrows
push out the shapt holder
install the new belt
close every thing
start to work
Apr 26, 2008 | Dryers
Kenmore 90 seies belt replacement
you have to remove the top and front panel,if you have a top lint filter remove the two lint screen filter screws,pull the top toward you and up,lint screen inside,most pull forward and up,so you might have to remove the two console head screws(one on each side,flip up and remove 4 more screws,now disconnect the door switch,now remove the 2 screws on the front panel top 1 on each side,now pull up and off,remove any other wires that might go to the door,now pull the drum out,now look down at the motor pulley wheel and the idler wheel,the belt goes around the drum,now put the drum back in place,now put the belt under the idler wheel and up onto the motor pulley,replace everything and your done-mike
Apr 05, 2008 | Kenmore 65924 Electric Dryer
Whirlpool ler5636eq3
check and see if belt is broke you have to lift the top and then remove the front with two screws on each side on the inside pull out and up. after you lift the top you will see the tub and a belt should be on it if so lift up on the belt it should be snug if it comes off in your hand bingo there is your culprit remove front and install new belt
Dec 27, 2007 | Whirlpool LER5636P Electric Dryer
Dryers Logo
144 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
