Question about Refrigerators
Whirlpool arg667 frostfree fridge/ freezer. fridge section not cooling, freezer basically ok. could it be a circulating fan? Help!
Yes it could be the fan,try completely defrosting it manually then restart it ,if you can then feel airflow it will be a fault in the defrost system,either timer,heater etc,if after defrosting manually you cannot feel airflow it will be the fan or fanblade faulty
Posted on Aug 13, 2008
My whirlpool side by side fridge/freezer is making a loud noise while running.
If the noise is coming from inside, the evaporator fan motor (the fan motor that circulates cool air located in the freezer section) may be the culprit. If noise is on the outside, the condenser fan motor may be the problem. This is the fan motor that removes the heat from the refrigerator to the room.
Jun 14, 2015 | Whirlpool Refrigerators
MY FRIDGE ISNT GETTING COLD
Whilpool uses a fan at the back of the freezer to circulate air. If it burns out, the fridge will still cool, but not as well.
However, these don't usually burn out. What usually happens is that ice builds up and prevents air from circulating. If that is the case then you probably need a new bimetal temperature sensor on your cooling coils. This sensor sits at the back of the freezer (behind the wall) and tells the fridge when to defrost. If it doesn't then the ice will plug up the vents and may even stop the fan from working. Hope this helps.
Apr 15, 2014 | Whirlpool Refrigerators
Whirlpool refrigerator does not cool on refrigerator side. Freezer side works as it should.
most fridges have coils on the freezer side and circulate cold air to the fridge side. if the freezer is freezing, then the air circulation to fridge is not taking place. find the air ports and make sure they are not closed or blocked (they should be adjustable to vary fridge temp) and check the fan on the freezer side as it achieves circulation.
Apr 10, 2013 | Refrigerators
My Whirlpool ET8WTKXKT0 doesn't cooling down. The fan is working, but the compressor like dead. What I have to check? Thanks. Victor
Its the problem with compressor,The problem is weak compressor.The refrigerant ( R12) in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that freezer not cooling this indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Whirlpool ET8WTKXK Top Freezer...
Model #3074AN the freezer is working but the fresh food section isn't cooling. was purchased new on 4/28/08.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Apr 04, 2011 | Whirlpool Refrigerators
My whirlpool fridge makes a loud humming noise when the door is closed. It is not freezing items in the freexer and is not cooling items in the fridge section. The freezer is above the fridge section in...
The fan is hitting ice build up...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 11, 2010 | Whirlpool Refrigerators
Fridge is not cool enough 12 degrees C. Freezer is -3 degrees
The cooling air outlet is clogged or blocked. Cool air is not entering the fridge section as indicated by the low temperature in the freezer section. It shows that the compressor is working fine and the system is good. If your unit has a brushless DC fan motor that circulates air to the fridge section, it may not be working properly or not working at all. You have to replace it.
Nov 08, 2009 | Refrigerators
Creda R335NW Fridge/Freezer. The fridge section is not cooling down anymore, The freezer is working ok. Any ideas please?
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
Jul 03, 2009 | Refrigerators
Fridge on Fridge freezer not working
Ok there is a drain pan under the evap. coil under the fan that may be clogged and full of ice there is a 3/4" hole the water drains out of that needs cleared if there is a puddle of ice over it , the ice will also effect the airflow traveling down the duct to the fresh food section of the unit.
If there is no ice puddle at the bottom of the refrigerator then make sure the unit is cooling well by making sure it has been running for 10 min. or so and checking the coil in the freezer , it should have a small layer of frost on it showing its getting cold the whole way through it. Let me know how this works.
Phil
Jan 02, 2009 | Zanussi ZI921 / 8FF Bottom Freezer...
Brand new refrigerator not cooling
ok what he was trying to say is that the freezer does all the cooling for both sides as nothing in the fride side cools and in order for the fridge to reach its proper temp the freezer should run any where between -0 to-10 then the fan in the freezer draw-es air from the fridge and cools it and circulates to the fridge now i need to know a few things is the compressor running is the freezer fan running do you see any frost on the back wall of the freezer section is the fan running in the back that's near the compressor to cool the condenser coils then i can better advise pleas hold my rating till we are done where did you purchase the unit
Jul 22, 2008 | LG LRTBC1825T Top Freezer Refrigerator
Refrigerators Logo
97 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
