Question about Hoover Washing Machines
My 5 year old Hoover 500 mb has started to stop mid cycle or not progress through the cycle !
Mate, I just had the same fault with the same model machine. The local machine repair man called me (i'm a sparky) to double check things for him. The macine stopped at the pre wash rinse part of the cycle every load. He replaced the timer with two NEW ones which both had the same fault as the original. We now suspect an inherrent fault in the timer design but as yet dont have an answer.
Posted on Aug 26, 2008
It is a Bosch WFF2000. The programme stopped mid
circle at bottom right take it off there is a filter there remove it and look of obstructions.WATER WILL POURE OUT!
Jun 23, 2010 | Washing Machines
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
I have a Hoover 550 MB Top Loader washing machine . The cycle won't move from wash to spin . it doesn;t progress out of wash cycle , it stays there forever .
Will the unit spin if you manually turn the timer dial to spin? If so, remove power, remove the clock motor from the timer, and inspect the clock and mating timer gearing for debris or damaged gear teeth. At the worst, replace the timer. You may be able to scrape or file the damaged teeth so that the timer will progress.
Oct 19, 2009 | Hoover HTC243 Top Load Washer
Machine died
It could be a lid sensor issue, due to the fact that pressing on the door seem to temporarily fix the problem. Then again, honestly im really not familiar with washers that old, so i don't even know if it would have a lid sensor, much like older cars don't have seat belts, so im not exactly sure when they started introducing lid safety switches on washers. In any case, i would try and check for a lid switch/sensor and if so, try finding a replacement for it.
Mar 13, 2009 | Washing Machines
Stops mid cycle
CHECK DRAIN PUMP AND DRAIN HOSE FOR RESTRICTION
Jun 01, 2008 | Fisher and Paykel GWL11 Top Load Washer
DU1100 Stops mid cycle.
main control cpu unit failing
needs to be replaced
May 09, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Hoover 550 MA Top Loading Washing Machine
if if spins the belt is ok,may have timer fault or timer module ( next to timer) if fitted will be faulty
Mar 24, 2008 | Washing Machines
Hoover 2305 washine machine wont spin
hi, i have a hoover 500 mb, occasionally it will not [ click into ] the wash cycle, then gets confused and does not spin dry properly
Jun 24, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
334 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
