When I insert a CD-R (TDK 52x) into my iMac it tells me that it (The CD) is locked and ejects it.....is this the wrong CD-R for an old iMac (OS9.2.1)? Thank you for the help.
  • 1 more comment
  • blcjec9 Aug 10, 2008
    Yes, I did try another CD it did the same thing, said it was locked.
    Yes, the iMac OS 9.2.1 plays other discs OK.....I wasn't able to begin to burn the CD it just kept saying the CD was locked. The file I intended to burn was some artwork on Photoshop Elements...but I didn't get that far.
  • blcjec9 Aug 11, 2008
    I will try a different brand of CD, that seems like the most logical solution, thank you...if not I will re-post the problem.
    Master:
  • 397 Answers
I can't say for certain with a MAC but when I have come across this problem on a Windows machine a firmware update will often solve the problem.
I doubt very much if there is a different firmware for MAC or Windows as all the firmware does is report what device and what characteristics the device has that it is installed on.
You don't seem to see it when buying CD's but I know that when you buy DVD/R's these days they include information about checking the firmware and the site where you can find information about your optical drive in order to make sure it is upto date.
One of the advantages of a firmware update is the fact that it allows your optical device to recognize more brands of media disks.
The reason I use Liteon optical drives in my own machines and all the builds I do is reliability and the fact I have yet to find a media disk they don't recognize.
Posted on Aug 11, 2008
  • 928 Answers
You may follow the discussion thread at the link below. That fixed the problem with the Mac not reading a blank CD.
LINK
Posted on Aug 10, 2008
  • Anonymous Aug 10, 2008
    That is a common occurence with the MAC OS after some time. May I ask if you viewed the thread at the link I provided?
  • 4,472 Answers
Does it play other discs ok? What is the exact model of the computer? and what program are you burning with?
Thanks,
Lee
  • 6,487 Answers
Did you try a different barnd of CD-R or another TDk CD-R and check if it will be working, because if you only try one TDK CD-R
sp better try another one and check if you will still have the sam problem..
  • Mark Gil
    Mark Gil Aug 10, 2008
    You're saying you tried another TDK CD-R and still have the same problem? how about if a different brand of CD-R do you have the problem??Beucase if you have the same problem using a different brand of CD-R the problem here will be your mdei device not the CD-R..
  • Mark Gil
    Mark Gil Aug 11, 2008
    The best way that you can do here is try another brand of CD-R because it seems Mac has some issue with TDK you can read alot of that on different forums.....
SOURCE:
My TDK 5900 CD recorder will not read CD-R 52x discs. Is there a software/firmware upgrade that will correct this?
The CD-R audio is not an obsolete format. Here's one set of writable discs from Amazon: https://www.amazon.com/Sony-50CRM80RS-Audio-50-Pack-Spindle/dp/B0002ZDIKW/179-2088873-7802310?ie=UTF8&*Version*=1&*entries*=0 . It is not the cheapest CD format, but they are out there. Amazon lists several other brands of CD-R Audio.
I hope this helps.
Jun 01, 2016 | TDK DA-9000 CD Recorder
I want to eject cd from cd rom apple system imac
To eject a CD/DVD that is not recognized by your computer, boot up while holding down the eject button on your keyboard, and continue to hold down eject until the disk ejects.
If this does not work, hold down your mouse button while booting up in the same way.
If neither of these work, open Terminal and type in the following:
drutil tray eject
If your disc does still not eject, your optical drive likely needs repair.
May 21, 2010 | Apple iMac G5 Desktop
I placed a dvd in the driver the wrong way round wont eject
Hello Dear,
You can always eject the Drive bay, forcefully, if it is not eject by pressing eject button.
To do so, find the small hole just benethe the CD tray, get a needle like thing and insert it into the whole, you cd tray will come out, now you can get it out by holding it by hand.
Thanks
Feb 02, 2010 | Apple iMac OS 9.1
Blueberry iMac with slot-loading CD rom drive will
It would be very difficult to open up the imac to retrieve the disc as the CD drive is totally enclosed and would probably result in it not be functional after removing the disk. Have a look at the following article on the apple website
http://support.apple.com/kb/HT3007?viewlocale=en_US as it does indicate that the slot loading imac does have a hole for paperclip ejection. You could also try opening up disk utility and and clicking on the icon of your disk under the left hand column then go up to eject button and click eject. Hope this helps.
Nov 12, 2009 | Apple iMac G3, G4 USB Keyboard 9224078
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
Tdk cd-r 52x recordable disc problem
bought a better brand of discs than TDK
Jul 03, 2008 | TDK (47951) 32x CD-R Storage Media
Problem reading blank disk
go to your burning software and look up disc info if it blank you will not be able to read it but it will show disc size space etc let me know how you get on
Brian
Jun 04, 2008 | LG Computers & Internet
Hitachi CD-ROM
A 1991 model is not going to be very fast. I've seen internal 40-52x ones at thrift stores for 5-6 dollars. External ones under 15.00
Feb 19, 2008 | Computers & Internet
TDK DA 3826 disc tray not functioning
Is the motor spinning to try to open the drawer?Can you hear it? Can you get something under the tray edge to try to 'help' it out when pressing eject?
Jan 05, 2008 | TDK DA-3826 2-Disc CD Recorder
Open Questions:
Computers & Internet Logo
47 people viewed this question
Ekse
Alun Cox
