Hi
Please check the parts for your KSM mixer on this link---
Kenmore KSM Mixer parts
Hope this helps... Please post back if you need more information.
Daniel
If sears said the part are no longer available you can try other parts companies like www.marcone.com under contact us or try allbrands appliance parts there is also a company out of massachuessets that same day appliance has went partners in that has a part find service they do charge about 50 dollars but they do put the part through all companies across the country in order to locate the part as well as ebay and other means this part will be hard to obtain and quite time consuming as well if you have any further questions message me back Thanks again I await your reply Rick
http://www.mrfixitappliance.com/Appliance-Parts-Same-Day.html this one also supposedly has kenmore parts
when you are finally able to locate that part you will find you have probably searched 30-40 of them this is what happens when these big companies discontinue there parts I ve seen thermodor do it to a 9000 stove 5 years later they discontinued the oven thermostat switch which then makes the oven useless after paying 9 grand I wish you luck in trying to locate your piece.Thanks again Rick
Try the sight given below for spares.
http://search.store.yahoo.net/buyitnow64/cgi-bin/nsearch?catalog=buyitnow64&query=kenmore+ksm035+mixer+pinion+gear+&x=17&y=8
beaters stopped rotating gears are stripped. I have a kenmore 16 speed 350 watt stand mixer and cannot locate parts. Sears said parts are no longer available I need pinion gear and rod. Can you help Can you help me locate the part. Model KSM035 Serial #23869239. I have checked with 5 different appliance parts and repair shops with no success.
Beaters stopped rotating gears are...
Problem with the Kenmore Mixers
beaters stopped rotating gears are stripped. I have a kenmore ksm035 16 speed 350 watt stand mixer and cannot locate parts. Sears said parts are no longer available. Can you help me need kenmore ksm035 mixer pinion gear and rod
The motor works but the beaters won't turn. How can I remove the head to get inside and check the gears?
