Question about Toshiba 62HM95 62" HDTV
How do I determine what is realy wrong?
How can I tell if it is the light engine that is wrong? In the begining the screen would get vertical lines, in all different colors. I would reset and it would be OK for a while. It kept geting worse as time went by. It Stoped going out when I put the A/C on in the house. After a month I turned the set on and the picture would come on and be OK for about 15 sec. and then go black. Every thing else workes The Sound, Changing channels works, Just no picture. I called the local Toshiba tech. He had no testing tools and seemed to no nothing about toshiba dlp's. I live in a small town and have no other people to ask.I told him what had been happening and he called Toshiba and they thought it was the main board. It cost over $1100.00 . I was hoping that it might be something else. please help I need to get it fixed but I havent worked in over 8 months and have very little money. thanks Gary
  • 1 more comment
  • garyndianf Aug 11, 2008
    I need more specifits. What site can I go to, to find a main board? what is a A/V fourm. Is ther any place I can send it to get it fixed etc. m Gary
    I contacted PTS eletronics and they say I need to be more specific on the part . what would the tec name be for the main board?
    I am having a problem. Can anyone tell me what the board is called. The people at PTS eletronics say that, the main board shows to be the power board, and the cost is only $100.00 The power is not the problem the set turns on and works fine just no picture. I tried to contact http://fixmymonitor.com/ but no answer on the phone and no luck at the site.
    Sergeant:
    Champion:
  • 248 Answers
You can find solutions here
Thanks! Good luck!
Posted on Aug 11, 2008
  • 4,889 Answers
It sounds like the mainboard but can be the flyback as well. The flyback transformer is the culprit in atleast 60% of the sets i fixed with similar problems. It is found on the large signal board on the right hand side. I suggest that you test if its alright before replacing the mainboard. Click here to get the testing instructions
  • eagle338
    eagle338 Aug 11, 2008
    Oops! i Forgot! The flyback transformer is a high voltage device and you should be extremely cautious while handling it. It has suction cup kind of plugs and and just squeeze and pull. You should avoid touching the ends of the cups where it makes contact with the board. Be careful. Your life and limb is worth much more than this.
  • eagle338
    Its recommended that you try the FBT first. It can save you atleast a 1000$.As for the board it is called the D-board. The part number will be located on the board itself in some sets. If it is so you can get me the part number so that I can help you find it for a lower cost.
    Master:
  • 521 Answers
The two things could be the mostly the problem
1)the fuse (which is very cheap)
2)the main board(which is very expensive)
if you get it replaced from a professional company technician you will get a warranty of about six months, and if get it your self you will definately save some money but it would be without garantee and thats more risky.
one thing you can do is get it checked by some local technician instead of company technician he will definately charge you less than the company technician and also give you the garantee on his own risk and also try to repair the main board if possible or try changing the fuse .
  • tech expert12 Aug 11, 2008
    it is also called power supply board
    yes it called the power board you are right
    Genius:
  • 1,665 Answers
It may be also a cold solder or bad electrolytic capacitor problem. but some special experience is needed in such troubleshooting work. Better take it to a n electronic repair shop unless warranty has not expired.
  • Toshiba Master
  • 6,487 Answers
Yes this can be a main borard problem just like what Toddg said and that needs a replacement already if you want you can check this site they repair any television and check if it will cost less than what the toshiba tech told you http://fixmymonitor.com/
Good luck.........
Posted on Aug 10, 2008
SOURCE:
My tv blinks and no power on the screen. People tell me its the bulb and someone also told me it could be the ballast
In a projection TV there are three CRT high illuminessence tubes no ballasts or bulbs, do you have a dot in the middle of the screen??? do you have a white line (horisontal or vertical)??? is it realy a projection TV not LCD or PLASMA???? post the make and model if you want us to help!!
Sep 24, 2011 | Televison & Video
Vega kdf-e55a20: All I see are Vertical colored lines across the entire screen. Could you tell me what the problem is and a potential solve?
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine,found the one you need here http://www.discount-merchant.com/SONY-1-788-156-11-p/1180225.htm?Click=48173 Have a blessed one!
Apr 21, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Mitsubishi 36'' TV not working....
HELLO
If you have a vertical line going from top to bottom of the screen you have what is called "Line Collapse" which indicates a fault in the line output stage. Don't keep your set on in this condition as it is possible screen burn can occur - switch it off and call an engineer in your area.
Apr 20, 2010 | Televison & Video
My tv wont turn on the light on the power button blinks and the lamp turns on in the back but the screen dont light up
check if crt screen voltage correct (g2) try to adjust screen settings at flyback transformer and monitor if g2 response, some model if vertical ckt down monitor have black signal only can determine if screen adjustment knob in flyback transformer turn increase. vertical line appear.
Mar 26, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Black screen with vertical lines through it
Could be faulty graphics chip or faulty screen. If you can hook up external monitor and picture is fine then probably faulty screen. If external monitor shows same problem the faulty graphics chip. Take to repair shop and let them have a look.
Jun 10, 2009 | Compaq Presario M2000 Notebook
Green Vertical Lines across screen- Sansung HLR5067WAX/AA
Hi, your are experiencing the first stages of a light engine burn out. it will fail soon. i recommend replacing the light engine asap.
Samsung Part Number: BP96-00822F---$895.00
May 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
My Ibm Laptop r51 has a vertical lines on the screen
Our service have 3 pcs of IBM r51 note. All of them has the same problem with the display (vertical lines). When I changed the LCD panel itself, I found that the source of the problem is the panel, not the video card, not the wireing... You only need to drop out the old LCD panel and get a new one. You cannot repair the wrong panel...
Dec 29, 2008 | IBM ThinkPad R51 Notebook
A line on the screen
Is the line perfectly strait? Is it seem to be yellowish in color? If it seems yellowish then the light engine is the problem is the blue panel is defective. Sony covers the light engine for two years. The labor you will probably pay for but, not bad concidering the part is 1000.00 or more.
Feb 01, 2007 | Sony KDS-R50XBR1 50" HDTV
Toshiba 62HM95 62" HDTV Logo
18 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
