Question about HP PSC 2210 All-In-One InkJet Printer
Hp psc 2210 won't initialize after a power outage, just makes clicking sound
Help! I have read several sites with suggestions for fixing this problem, but nothing works. I have removed the glass and cleaned the inside, tried three different resets from HP, tried doing a diagnostic cycle by pressing the cancel and color buttons, then going through all the buttons as directed by the display. Several times I have disconnected the power cord from the back of the printer and plugged it back in, then when I hit the "on" button, again it starts to initialize and continues clicking until I turn it off. This has happened everytime we have a power outage for the last few years, and usually after about a dozen tries, it finally initializes and I'm in business. Not this time, though, and I'm ready to toss this machine. Any advice out there???? Thanks, JoAnn
  • szachta Aug 22, 2008
    Thanks for your help. Unfortunately, nothing has worked, even the reset you suggested, so we are now shopping for a new printer. This one is 5 years old, so maybe it's time to move on even though it was a good printer when it was working. How sad these things just don't last as long as they should!
  • 4 Answers
I've had that EXACT same problem before. I suspect there is a sensor somewhere that tells the motor that the head is in full retract position but I'll be damned if I can find it! What you're hearing is the drive belt slipping over the motor gears because the motor won't stop but the head can't move any further. The moter works in timed phases so the sound is like a loud:
click,click,click,click...pause...click,click,click,click...pause...
Unfortunetly this a mechanical/electrical problem that can't be fixed thru the user interface.
Posted on Aug 21, 2008
  • Anonymous Aug 21, 2008
    Just wanted to add that I've been dealing with this problem for 2 days now. I've taken the printer top completely apart to watch what's happening. So far the only thing that seems to reset the head is to unplug from the back of the printer> wait 20 seconds> plug back in.
    This seems to work (sometimes) so now I'm wondering if it really is a sensor screwing up or something else. I also found a way to do a BIG reset. Unplug from the back>wait 20 seconds>hold down the # key and the 6 key and plug back in. It seems to run a different reset routine. Good luck!
I too, have the same problem with the 4 click and a pause when the machine if first turned on. Like XerteX I took the machine apart and, specifically the top plastic unit that holds the glass. Setting the glass unit on the printer and turning it on I found that the "chatter" would cease as soon as I lifted the top unit straight up...when separated about 2 inches from it's resting point the chatter stopped. So there is a sensor part contained in that "box" above the head that reacts with the head but I had no success in pin pointing its location. Strangely enough, the printer has not chattered once in the past week since I put it all back together. Perhaps the removal action stimulated something in the sensor. Anyone have a clue as to thew function of this head sensor ?
Posted on Oct 10, 2008
  • Anonymous Oct 18, 2008
    Mig-mig: Please expain how you moved the head closer to the sensor strip.
Well, somebody mentioned the white stripe at the end of the glass which is like a STOP sign for the scanner lamp. Well, at one end of that stripe there are some letters and numbers for which I concluded they mean STOP and because I noticed that the lamp does not pass under it I shifted the lamp a little bit thowards them (one milimeter) and the thing finally worked. Is it possible that the lamp thru time or transport moved?? Anyway, if anybody elese has this problem try to do this!
For me, now I have to solve the problem with nonoperable software fo scanning.
Bye
Posted on Oct 17, 2008
I had the clicking problem during initialization, I reset as some of you have had limited success. Great - no clicking - but printer does print - I am dumbfounded
SOURCE:
SCANNER FAILURE
The issue is with hardware of the printer.
Scan feature is most expensive and sensitive part of the printer.
I suggest you to contact HP support. If the printer is under warranty you may get a replacement printer or else they may give you a better option.
If not on warranty you may try this workaround:
  1. With unit off, press the 'Cancel' (pink button) and 'Color' (green button).
  2. This will start the printer in a diagnostic mode. Press '1' to run the diagnostics.
  3. Press 'Enter' or other keys as directed by the display prompts. When you don't know what to press, the 'Enter' key usually works. Some of the keys called for (for example 'Plus' and 'Minus') are not on every psc 2210 keyboard. They are mapped to one of the "directional" keys just above the numeric keypad area next to the 'Enter' key. Keep trying keys till one works.
  4. After all the diagnostics, the display will either go blank or display 'Initializing...' . Wait 10-20 seconds to make sure it isn't doing anything else then press the 'On' key.
The printer should start without the scanner error and the grinding/chattering noise.
Leave the printer on because the next power cycle brings the chattering noise back.
But, when it does, the procedure above seems to fix it every time.
PSC 2210 scanner failure HP Enterprise Business Community
Feb 18, 2014 | HP PSC 2210 All-In-One InkJet Printer
I have a hp psc 2210 all in one priter bthat won't
you need to go to HP.com and download the 32 bit Vista drivers.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 04, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hp psc 2210 all in one printer
You can't load the software that came with the printer.
HP has a Vista page for your printer. Here is a link: PSC2210 Using Vista
Basically, you need to uninstall the software AND delete the printer from your computer. Disconnect your USB cable. Power up your printer. Connect the USB cable.
The above link gives some workarounds for scanning and importing images.
Nov 07, 2008 | HP PSC 2210 All-In-One InkJet Printer
Won't initialize
You've stripped something out, its a mechanical problem. Probably on the bar that drives the print head.
Aug 03, 2008 | HP PSC 2210 All-In-One InkJet Printer
Printer Issues
my hp psc 2210 after putting in new cartridge keeps saying press enter to align cartridge. it keeps repeating the same reading.
Apr 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
Prainter failed without warning,will not respond
Hi Tcov,
Please click on the web link given below and perform the steps as provided in the web page.
Please read the documentation provided in the web page carefully to fix the issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00045587&cc=us&lc=en&dlc=en&product=79499
Have a great day!
Feb 02, 2008 | HP PSC 2210 All-In-One InkJet Printer
PSC 2210 Scanner Doesn't Work
I'm not sure about this specific model, but I've had similar problems with other HP all-in-ones and usually what fixes it is uninstalling and reinstalling the software (make sure to follow their directions properly and not plug the printer in until they tell you to). You should also make sure you're using the most updated software from the HP website rather than the one that came on the CD with the printer which may be outdated.
Jan 05, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
1,137 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
