Question about Protron PLTV3250 32 in. LCD Television
I get a blue screen when i turn on my playstation 3.
The HDMI component of my tv blanks out when i put on my ps3. everything else on the tv works fine, except the hdmi. the ps3 works well on other tv's and is set onn 720p
  • 2 more comments
  • Anonymous Aug 26, 2008
    I get a blue screen when i turn on my playstation 3 saying no signal but tv works great just no display when using hdmi
  • robnsteph Nov 17, 2008
    I have the exact problem. I just went and exchanged my PS3 thinking that there is a default with it, but my new one is doing the exact same thing. Turning the TV off and then back on does not work for me. I also noticed that on my TV under the settings option, that the HDMI is not highlited so there is no way that I can change or modify that option there. If anybody has another solution to fix this issue, please help!?!
  • 9man Dec 30, 2008
    I get a blck screen with a purple line runiing up the left side. PS3 works fine in the A/V mode. Tried to cut TV off and back on, but this does not work. The HDMI did work for about 72 hours and then I started to get black screen with purple line. Please help. I am on my third PS3. It has to be the TV.
  • Anonymous Apr 29, 2009
    i have the same problem
Same thing happens to me, turn the tv off and back on, it will work fine then.
Posted on Aug 13, 2008
I sometimes would get that on my XBOX 360 w/HDMI, I just turn the power off and then back on and it works just fine. I have mine set to 1080i.
Posted on Jun 15, 2009
Samsung TV Is Not Picking Up A Playstation 3 HDMI Signal
If you are able to connect your PS3 to another TV using the same HDMI cable that would rule out your PS3, if it works.....or
does the PS3 itself have any settings that perhaps need to be set to an HDMI output as opposed to Composite or SCART etc?
Also have a look at the HDMI settings in theh TV menu too.
Jan 10, 2014 | Video Game Consoles & Games
I just get a blank screen with no sound or anything when i turn it on
I once had this issue, the solution was hard to find(five hours), but fairly simple. (This works for HDMI cable set up, but I'm not sure concerning AV)
Note: Yes, the solution sounds ridiculous, but for this issue, it works.
1. Unhook your PS3 from the current TV/Computer screen you have it hooked up to.
2. Hook it up to a different TV/Computer screen that you have or a friend may have.
3. Power on the PS3 and it should have a screen and everything and work just fine.
4. Hook it back to your original TV/Computer screen and power on the PS3 and it should work fine there again aswell.
Jan 23, 2011 | Sony Playstation 3 (PS3) Console
After installation of ps3 and blue -ray disc remote control. tried using remote to turn on and play a dvd dics to no avail nothing works the ps3 player nor the remote does't appear to recognize each other...
Ive had the same problem with mine. I have a universal remote and a blu ray player separately installed on my tv. The only way i was able to play the ps3 without calling geek squad to reconfigure my tv was to unplug the blu ray and put the ps3 in its spot and push watch bluray. It worked great.
Nov 29, 2009 | Sony Playstation 3 (PS3) Console
When i turn on ps3 all i get is a blank tv screen? hooked up thru hdmi. triied another hdmi cable i know works still a blank tv screen
when you turn your ps3 on ..try holding the power button down for about 10 seconds..that shud cure your delema..if the ps3 is working properly
Nov 06, 2009 | Sony Playstation 3 (PS3) Console
Ive had my PS3 hooked up using HDMI for years now but i bought a component cable because i have just bought a PVR and it can only record using component and not HDMI. The problem im getting is that when i...
Hook it up with the component cable and then hold the power button on the console until something comes up on screen. Make sure you have selected the component input on your tv or else you wont get anything anyway.
What holding the power button does is it resets the video settings to the lowest common denominator and then you can reconfigure it for the optimal picture quality of the component cables.
If that doesn't work double check the component connections on the back of the TV and just make sure they are where they should be and that no accidents were made while hooking it up.
Please post the results from these steps here so that I know what happened.
Jun 09, 2009 | Sony Playstation 3 (PS3) Console
Cannot get my HDMI cable linked from my ps3 2 my hd tv
Try video settings on the playstation 3. Adjust it to reflect hdmi.
Feb 22, 2009 | Sony Playstation 3 (PS3) Console
PS3 won't connect to TV with component video.
You need to connect the PS3 to the television with both connectors (HDMI and Component). Then in the display settings change it from HDMI to component and during the 30 seconds that the screen goes black you need to disconnect your HDMI cable from your playstation. Then switch to the input that the component cable is connected to on your television (ie. AV1, AV2, etc). From here you will see the countdown for the test and you can continue with these settings.
Nov 20, 2008 | Sony Playstation 3 (PS3) Console
PS3 or LCD TV?
when the ps3 is in standby hold down the power button for over 4 seconds, it runs the optimal screen settings page. hope this helps
Feb 26, 2008 | Sony Playstation 3 (PS3) Console
Samsung LCD tv and PS3
the problem is with the frames per second that the ps3 is putting out. i wound up calling both samsung and sony and the problem was in the settings. the ps3 allows you the option of playing in 24hz and for some reason if the option isn't turned off our tvs won't display frames at that rate. just go to the dvd settings and deselect the 24hz option, changing it from AUTO to OFF... the only problem i have with this is that this should effect the picture quality, becasue if it isn't displaying in 24hz that means it is downscaling the display and if it isn't upscaled by the tv's processor, then the display should be worse. i might be imagining it, but it does seem worse.. atleast they play now though. hope i helped.
Nov 03, 2007 | Sony Playstation 3 (PS3) Console
HDMI Cable
if ur setting up the HDMI cable dont check all the resulusions just check the 1080i coz 1080p is to high for your TV thats why you have that blank screen for 30 sec.
Jul 28, 2007 | Sony Playstation 3 (PS3) Console
Protron PLTV3250 32 in. LCD Television Logo
1,535 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
